Results 1 to 4 of 4
Thread: '99 vs statesman, tacho jumping round on decelaration
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Exclamation '99 vs statesman, tacho jumping round on decelaration
    My '99 Supercharged VS Statesman's tacho jumps round from 1000 rpm to 1800 rpm when i go down hills at speeds of 80 kph and over is it normal or
    what do you think is causing it because it doesn't surge like it the engine is actullaly reving but the tacho still moves.
    And a second question, the temp gauge never moves over 1/4 mark and usually sits just above the cold mark is this going to hurt the engine or should it be ok, i think it might have something to do with my climate control always feels cold than the read out on the display?
    Thanks for any help you can give!!!!
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Check the rear of the cluster for dry joints.
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    My guess which may be way out is the the TCC (torque Converter Clutch) is locking/unlocking for some strange reason on over-run. I think on over-run or going down hill it should unlock and then stay unlocked till a steady speed above 80kph is achieved on a constant throttle setting. The fact that it only happens around 80kph kind of indicates that it is transmission related as this is the speed that the TCC comes into play.
    Do a codes check - maybe there is a transmission fault logged there.
    Checking error codes VR/VS (Revised)
    Good Luck.
  1. jumping speedo meter
    By h0Ld3n`VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-12-2007, 12:44 AM
  2. jumping around
    By limited_edition_vl in forum General
    Last Post: 16-02-2007, 07:15 PM
  3. idle jumping around.
    By dlzn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2006, 12:41 AM
  4. idle jumping
    By impressive in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2006, 04:53 PM
  5. Clarion stacker jumping
    By lasco in forum Car Audio
    Last Post: 23-09-2005, 02:11 PM
