Does any one know how to remove the hand brake button on a vs???
Im putting on the chrome isotta one so please help!!
cheers
Look at the similar threads section below, your answer is there.
Mine was terribly warn out, I couldnt even press it in (if I did, it would get stuck in).
You can unscrew it normally I believe, I had to use a philips head screwdriver and hack away at it til it was all gone.
the rubber button that you push in?? it simply pushs on and pulls off
Then wouldn't the spring behind it eject it? lol
Current mods/repairs:
Power Windows Installation (70% Complete)
Current Issue(s)
N/A
My Holden doesn't leak, It's just marking it's territory!
they only eject if the rubber is worn out and it doesnt stay on the shaft under the pressure of the spring, ive seen them hit windscreens while driving funny as you dont expect it...
if you just pull the button off the spring stays over the shaft & doesnt eject and is very easy to push back on
It was common in the VS for the handbrake button to "spread" with use and get caught in the handle. I went through a second one, but the problem recurred some years later. The last one that I bought was of a much firmer rubber, and it was fine for many years.
As previously advised, the button fits on the shaft by interference fit over a knob. It pulls off with enough effort.
MMMmmmm makes me almost want to install a button - I press the metal pole nowworks great.
Current Issue(s)
N/A
lol.......
rebound off the dash? put 2 and 2 together? common sense would kill some people... but in relation to this how to you get the rubber grip off like the plastic / rubber handgrip i wanna change it biut i cant see a screw on it and ive reefed off it n everyting and it wont budge haha
