Results 1 to 4 of 4
Thread: vs console removal
    holden_man86 is offline Banned
    vs executive commodoer
    Feb 2009
    Default vs console removal
    need help on takeing out concole and dash in vs commodor
    iam happy to call if you dont mind just pm your number to me
    thanks
    scott
    Feb 2009
    Maranello red Vn V8 Calais
    Jan 2009
    like i said in my earlier pm, remove the dash piece that surrounds your gear lever by pulling upwards on the lower part of it, it will click up and can be removed (easiest to put it in neutral and weave it over the gear selector) also the ciggy lighter will need to be removed, it simply had a little nut on the under side of it which should unscrew by hand..
    ow open the centre console and pull up the carpet at the bottom of it, you will see two screws, undo them and the centre console will lift out.
    The dash itself is only held in by 2 screws once you remove the outer trim that surrounds it.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    To remove the cluster go to:
    Broken Odometer
    To remove the console go to:
    Installing a Stereo into a VN - VS
    Good Luck.
  1. centre console removal
    By Holden V8 SS Ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2008, 04:26 PM
  2. VZ center console removal
    By Troy711 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-04-2006, 08:37 PM
  3. How To: Doors and centre console removal
    By premmy186 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-02-2006, 12:46 PM
  4. VR Centre Console Removal
    By SMIT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2005, 04:35 PM
  5. Console removal
    By Carson in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-09-2004, 02:37 PM
