Results 1 to 22 of 22
Thread: Carputer connector cable
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Default Carputer connector cable
    Hey guys, I've got an old laptop, that's been stripped back and been made ready to become part of a carputer.
    Anyhow, my question is: Can I make a serial cable from this:
    DealExtreme: $16.32 SI400 SI-Reset OBD-II for BMW
    I can't see why not... your input will be appreciated
    OzJD.
    Edit: I should add the reason I'm asking - I havn't found a connector that's at a somewhat decent price.
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
    96 VS II Acclaim
    Dec 2007
    I think the pins might be different.
    Look for an ALDL cable.
    How are you planning to wire up the pc? are you going to connect it to the dtc socket?
    Commydoor's Avatar
    Commydoor is offline born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    ive got an OBD-11 kit....the plug connects to the diagnostic link and in the back of it is a USB that the cable connects to that runs to my lappy....all it would need is a cable that runs from USB to serial port to connect it to an old lappy or an adapter...say from a puter fair...that one on there looks like its for a BMW and has a sd card slot into it with the info on it...on the other hand if you just want to make a serial cable then why not just use a serial cable from say a really old modem or serial printer...ive got heaps of old cables here....even an old extension printer cable from memory i think id have to check....lemme know if you want it to experiment on..
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Quote Originally Posted by WhiteOx View Post
    The pins look the same to me :-S
    I'm not sure WHERE i'm going to connect it yet, but I think it will have a switch to enable/disable data
    Current Issue(s)
    N/A
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Quote Originally Posted by Commydoor View Post
    Allthough I have USB ports, I'd prefer to use Serial Cable (because the laptop has it and the serial cables screw in). My issue with it isn't the serial end, I'm just trying to work out if that connection will fit the commodore
    Current Issue(s)
    N/A
    96 VS II Acclaim
    Dec 2007
    Quote Originally Posted by OzJD View Post
    The way the pins are wired is what I meant.
    Have a look here:
    aUSTRALIAN SCAN TOOL
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    This thread might be of interest to you, if not maybe contact the OP for advice or contact Doctor Bob.
    DIY: ECU Scantools/Data Cables
    MY RIDE
    michaelw's Avatar
    michaelw is offline Donating Member
    VX S2
    May 2005
    Newcastle NSW
    Short answer:no
    Long answer, it is the same plug but the electronics are totally different. I make the aldl adaptor and sell it here but only in a usb form.
    If you want just the bare plug we can sort something out.
    Mike
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    michaelw's Avatar
    VX S2
    May 2005
    Newcastle NSW
    That (the above photo) won't work on the commodore v6 as it is a OBD 2 cable, the v6's run aldl. I know it is the same plug but it is a different protocol.
    Mike
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    but wouldnt the obd-2 plug work the same as the ALDL? I mean, if it it just using some of the pins, couldnt u wire them to the output?
    If you are making USB plugs, are they native USB or Serial->USB conversion?
    Regards,
    OzJD
    Current Issue(s)
    N/A
    VS Commodore Omega
    Apr 2005
    I've found the USB -> ALDL cables are serial adapters because it's what's needed for EFILive amongst other software... The cables are getting expensive now though, this one's $170 inc postage (link), lucky I got mine when he was selling them for under $100 lol
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Even $100 is a dead rip off as far as i'm concerned.
    Because the USB controller is emulating a serial port, it's not any faster, just alot of newer computer don't have serial I guess. (but having a screw in plug is far more convenient for a permanent application)
    If the plug is the same on the US$16 one I mentioned above, can't I just add a serial port and some wiring between? :S
    Current Issue(s)
    N/A
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Actually, for US$6 ($15.19 AUD including $3.60 postage) there is this: Obd2 Male Connector - OBDii Connectors: Car Plug
    Current Issue(s)
    N/A
  15. #15
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Ok, Here's what I've decided on (and looks most likely to happen - unless someone comes up with something more appealing).
    I'm going to buy a $5 mouse (with serial connection).
    I'm gonna rip the wires out of the mouse, and chuck the mouse part.
    I'm going to make a cable with that, using the diagrams on this site, and hardwire the cable to the diagnostic connector (no plug) - This is going to be a permanent install, and it means I can disable the cable if the engine light is flashing or I need to use the connector for something else
    I'm going to install 2 switches:
    The first switch will Turn on/off the cable
    The second switch will "jump" the two wires to show diagnostic codes on cluster
    Opinions?
    Current Issue(s)
    N/A
  16. #16
    VRII Acclaim
    Jul 2005
    Car wont show the engine light if the diagnostic connector is connected. There shouldnt be any need for a switch to turn it on and off. Using a second switch to show codes on the cluster, just make sure youre not shorting anything on the circuit. Dont think you would, but best to double check.
    Seriously though. I can get all the electronic parts for free, I would simply have to buy the connector which is available from Jaycar. Even then I would still buy a completed unit of michaelw. He has done a heap of work designing the circuit, he offers a good price to justcommodore members and the result is very professional.
  17. #17
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    It's not so much that I don't believe in MichaelW, it's more so I know I can do it fairly cheap, and I'd much prefer the serial cable than a USB which *might* fall out etc.
    RE: Switch 1, I've read on here that the check engine light flashes when sending/receiving data?
    Current Issue(s)
    N/A
  18. #18
    michaelw's Avatar
    VX S2
    May 2005
    Newcastle NSW
    Don't worry, no offence taken. I posted the DIY so that people who wanted to give it a go can. For the effort I'd skip the $5 mouse plug and just get a serial plug from jaycar, in fact all the parts for my circuit can be bought from jaycar. The design I sell uses the same front end (with SMD parts rather than through hole) with a different translator circuit.
    I would also use the schematic I have designed as I know it works with the VR. That design came about due to an embarrassing situation where I have the old techedge circuit on a mates VR and it did nothing.
    As for the OBD vs ALDL two totally different protocols. Different pins are used, different voltages and different code structures. In my OBD circuit I have a microcontroller that does the translation.
    The engine light on the VP/VN flickers during communication, the VR wont.
    Good luck with the project.
    Mike
  19. #19
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    The USB cable will not fall out, plenty of ppl with carpcs and noone has had any problems with USB cables falling out, even 4WD's
    absolute worst case, u plug it back in, not that hard
  20. #20
    michaelw's Avatar
    VX S2
    May 2005
    Newcastle NSW
  21. #21
    vs
    Jan 2009
    Hey there
    Can you post the circuit diagram that you found works with the vr commodore
  22. #22
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Use search mate (I can't remember where it is)
    Current Issue(s)
    N/A
  1. Carputer
    By vsquest in forum Car Audio
    Last Post: 23-04-2011, 10:03 AM
  2. [NSW] WTB: bits for carputer. (new/used)
    By VRV6BT1 in forum Swap / Wanted to Buy / Trade
    Last Post: 06-12-2008, 01:11 PM
  3. carputer?
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2008, 08:18 AM
  4. Carputer
    By Bilbs in forum Electrical Wiring / Questions
    Last Post: 10-12-2007, 06:21 PM
  5. VS Series II Carputer
    By harmer56 in forum Car Audio
    Last Post: 10-11-2006, 11:28 AM
