Results 1 to 13 of 13
Thread: tie rod ends and handbrake, need work for a wof
    PSYKO PHOENIX's Avatar
    PSYKO PHOENIX is offline AHHHH brain fart
    1995 VS Commodore v6 ecotec
    Nov 2008
    rotorua, NZ
    Exclamation tie rod ends and handbrake, need work for a wof
    hi guys i wet for a warrent of fittness today and the vs faild, its got a warn left outer tie rod end and aparently the hand brake goes up to far (although how that makes it unsafe to dirve ill never know)
    so to anybody who can help
    how do i change a tie rod end?
    how do i ajust the hand brake so it dosnt go up so far?
    thanks in advance for the help guys
    you dont turn a holden off
    you power it down!
    for any one who asks, holdens dont leak oil, there marking there territory
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    tie rod ends i'm pretty sure just screw on (btu don't quote me, i've only had it done by a pro)
    handbrake is easy, there's an adjustor either under the car or under the handle itself, i forget where, but either way it's just turning a nut or 2 to adjust
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Have a look in the "how to" section as I think its covered there. If not there then I'd do a search for "tierod ends" and "adjusting handbrake"
    LightningVP is offline Donating Member
    None
    Sep 2008
    To adjust the handbrake you will need 2 10mm spanners (or they may be 8mm), and under the car (directly under the car), put some blocks at your wheels put your handbrake down, then loosen the 2 nuts, and send them up the thread...Go back into your car, then slowly pull the handbrake up, should make 5 clicks. if it makes too many continue to sent the nuts up the bolt, if it makes less, then get back under and bring the nuts back down. Once it's at 5 tighten the 2 bolts against each other (turn one clockwise, the other anti clockwise)
    Nov 2008
    rotorua, NZ
    choice, the hand break sounds easy enough, im having trouble finding how 2's on the tie rod ends
    you power it down!
    None
    Sep 2008
    Quote Originally Posted by PSYKO PHOENIX View Post
    handbrake is VERY easy, once you get under you'll know exactly what I'm talking about, and depending on how low your car is, you wont even need to use a jack. But just remember to use blocks, and to have handbrake down
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Tie rod ends unscrew off the tie rods, this part is easy. The hard part is seperating the tie rod end from the 'stub axle' or whatever its called. You need a special tool for that. You will need a wheel alignment after you replace them , so you might consider getting a quote for the whole job from a tyre / suspension shop.
    Nov 2008
    rotorua, NZ
    Quote Originally Posted by greenacc View Post
    do you or anybody know that the special tool is??
    you power it down!
    VX Executive
    Nov 2008
    Bolton point Newcastle
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Nov 2008
    rotorua, NZ
    ill try get the steps and pics up soon for you to see, its realy easy
    you power it down!
    VP Exec
    Jun 2005
    While the quick (and dirty?) way to adjust the park brake is to pull the cable tighter using the adjusting nut found under the centre of the car, the right way is to back the cable tension off using the nut then adjust the tensioners for the park brake shoes found inside the rear disc top hats.
    There are access holes in the backing plates (look for the rubber plugs that should be in each of them) that will allow you to turn the adjuster that pushes the shoes out into the disc top hat from under the car.
    Alternatively, you can pull the discs off to move the adjuster. Then you can go back and adjust the cable tension. 7-8 clicks is about right for a VN-VS to avoid the shoes dragging.
    94 vr HSV gts 6speed 5.7stroker 215kw
    Jun 2009
    no where
    undo the tie rod nut get a hammer a good heavy one and smack the steering spindle you will have to hit it a few times but it will pop out i do it when ever i change my tie rods always works
  1. Rack Ends
    By djlingard in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-08-2008, 06:57 AM
  2. Trouble never ends...
    By asustek in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-04-2008, 02:42 AM
  3. tie rod ends
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-02-2007, 09:28 AM
  4. Marketing 101 - Does anyone know how this ends?
    By BlackVXGTS in forum Jokes/Humour
    Last Post: 22-08-2006, 01:36 PM
  5. it just never ends
    By impakt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2006, 10:23 PM
