Results 1 to 11 of 11
Thread: Spray painting
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Exclamation Spray painting
    im planning on spray painting my engine bay and some of my exterior (door handels ect) is it ok just to use a grey primer frist then use a normal gloss or matt black spray paint on them? or do i need to use a differnt spray paint?
    theres prob a tread on this alrdy but im rly short on time as i need to get it b4shops close, so im sorrry if this has been posted alrdy
    any help would be greatly appreciated
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    VS Calais Series II
    Feb 2009
    How are you planning to spray the engine bay. Obviously no engine in there and fully stripped.
    Well you need to sand the original paint down so that the primer can adhere to it.
    First wipe it down using wax and grease remover then give it all a light sand using something like 320 grit.
    Once sanded clean the whole area and wipe again with wax and grease remover.
    Prime the surface that will be painted. If you are using 2pac paint you will need a 2K primer.
    Once primed and left to dry you will need to wet sand it with 800grit all smooth like glass. As its an engine bay you know which parts will need to look good the rest can be sanded quickly.
    Once primer has been sanded, once again clean the area and wax and grease remover.
    Now mask off all areas that you dont want paint on.
    Hit it with your paint.
    If its just acrylic paint you will only need to get a acrylic primer. Matt black is cheap and you can buy it in a can.
    on the door handles just get some colour match to the car after priming just spray them it comes in a can and they will colour match the paint to the car.
    LET ME KNOW IF YOU WILL BE USING A SPRAY GUN OR CANS
    IF THIS IS WHAT YOUR DOING LET ME KNOW ALSO AND I CAN GIVE YOU MORE DETAILED ANSWERS
    VS Calais Series II
    Feb 2009
    More info on what you want done and how good you want it to look.
    By engine bay are you meaning engine pieces and components or the actual bay???
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    just pieces like the black cover fading over the cooler fan, sorry didnt word it right not the whole engine bay lol
    VS Calais Series II
    Feb 2009
    Ok yeah thats pretty straight forward.
    Get some high temp spray paint any colour you like. Make sure its a high temp if your putting it under the bonnet or else it will melt.
    you can simply just sand the plastic pieces down and paid them straight over without the need for primer.
    so get a bucket of water with 2-3 drops of dish soap and leave the sandpaper in the bucket for 5 minutes. (use 600 - 800 grit)
    whilst you wait just wipe the pieces down or wash them.
    now keeping the parts wet just sand them using your wet sand paper lightly.
    once you scuffed them up a little just wipe them down dry.
    when dry wipe them with a bit of methylated spirits to get the grease and dirt off.
    place the parts on newspaper or elevate them on a cardboard box and spray them.
    give it a light mist coat first let it dry for 5min.
    then hit it with a couple of medium coats until all covered allowing 5 min between coats.
    let them dry in the shade not direct sun for a few hours or over night that way you dont leave finger indents when replacing them and your done.
    same with door handles.
    you can use cheap spray cans for the door handles and no one will tell. black is black.
    however for under the bonnet i recommend getting the high temp paint.
    if its enough you can use the high temp paint for both.
    IF YOU DO WANT TO USE PRIMER YOU JUST NEED TO PRIME IT AFTER YOU SAND IT, LET IT DRY, SAND THE PRIMER SMOOTH AND THEN PAINT.
    SO JUST 1 extra step.
    primer just allows the paint to adhere better to the plastic but ive used paint straight on plastic and its held up fine without any primer.
    GOOD LUCK
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    kk awsome thanks for detail bro, appreciate it mate
    cammed Vx ss m6
    Sep 2006
    Quote Originally Posted by EREXON View Post
    GOOD LUCK
    i would be using plastic primer...... they can come in small spray cans
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    yeah i was going too anyway wanna get it done right the first time
    VS Calais Series II
    Feb 2009
    Its up to you mate.
    Plastic primer can be used depends how fussy and how long you want it to last.
    Iv used both ways with and without primer, and both are fine but for a really top job id use primer aswell.
    The other thing make sure you dont get primer "FILLER" for plastic as it will build up a layer to cover any small holes and cracks which you dont need on the plastic parts you're painting. It will just take longer to sand smooth.
    so a normal primer to cover it all up will do.
    VS Calais Series II
    Feb 2009
    3 coats of primer and 3 coats of paint is usually enough.
    all come in spray cans.
    Just make sure you keep it clean before paint. The paint bit shouldnt be a problem as long as the surface is sanded right and clean.
    cammed Vx ss m6
    Sep 2006
    most plastic primers arent meant to be sanded after applied just painted straight on top
  1. Replies: 4
    Last Post: 23-09-2006, 03:21 PM
  2. Spray Painting
    By 05 VZ SS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-09-2006, 11:29 AM
  3. Spray Painting - I suck
    By Stupid Stupid Stupid in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-05-2006, 04:27 PM
  4. Spray painting questions
    By Shounak in forum General
    Last Post: 09-11-2005, 04:58 PM
  5. Spray Painting My Beast
    By Holden_Chickie in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-09-2005, 05:36 PM
