Results 1 to 4 of 4
Thread: !!cant get rid off bubbling sound!!!
    vr executive
    Nov 2008
    Default !!cant get rid off bubbling sound!!!
    i gota vr exec and theres a constant bubbling noise behind the steering wheel. i know that its air in the cooling system or something like that and you have to bleed the system when the heater is on....only this is my heater doesnt work...what should i do guys??
    cheers jordan
    dufus is offline Donating Member
    rickshaw
    Jun 2006
    Take the single vacuum hose off the heater tap, this will open the heater tap allowing water to flow through the heater core, you can now bleed the system.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If it's bubbling that means the heater is on - the sound usually comes as coolant circulates thriu the heater. It's possible the heater tap is partially blocked allowing on a dribble to flow.
    vr executive
    Nov 2008
    where is the single vaccum hose on the heater tap??
LinkBacks (?)
  1. bubbling/water sound coming from dash
    By tep_aus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-06-2009, 12:37 PM
  2. Oil bubbling from head?
    By pimpjuice in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2008, 08:34 PM
  3. Bubbling Paint
    By Grennan in forum General
    Last Post: 30-04-2007, 10:49 PM
  4. bubbling radiator
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-07-2006, 07:20 PM
  5. bubbling problem
    By sulley in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-12-2005, 10:47 PM
