Results 1 to 8 of 8
Thread: Central Locking
    VR calais
    Feb 2009
    Angry Central Locking
    Hi i have a 95 VR Calais, my problem is that when i use the central locking the front doors lock and the back doors stay unlocked...... does anyone have a solution or is there something wrong with my key?
    VR stato
    Dec 2008
    yah theres a few post on this.... put after market central locking motors in the back doors or just try taking locks out and puttin some graphite powder on them...
    VB SL/E
    Dec 2008
    Quote Originally Posted by 95 VR_CALAIS View Post
    Have you had the door trims off to see if the wires are connected?
    The car may have had repairs by a previous owner and could have been damaged.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Quote Originally Posted by richardbignutsonstato View Post
    Follow this advice. They get worse over time, and temperamental. I know with mine, sometimes the left one will not lock, other times its the right side, and other times both lock like normal!
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    dufus is offline Donating Member
    rickshaw
    Jun 2006
    Yep best to just swap them out for newies, i know ive had to swap my front passengers one because it was extremely temperamental at times, swapping it solved the problem.
    VR calais
    Feb 2009
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Not nesacarily. Just try lubing up the tie rod where it goes through the guide across the back door first. Plus give everything a lube up and it can fix the problem.
    Mine used to play up in the wet alot. The moisture in the air used to make the guides sticky.
    Reaper
    rickshaw
    Jun 2006
    Quote Originally Posted by VrWagz1 View Post
    Not really worth the effort when new locks are soooooo cheap and it means you wont have to worry about it for another 10 years
  1. central locking
    By brooksy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2011, 09:41 AM
  2. Put new central locking motors in but central locking still doesnt work???
    By richardbignutsonstato in forum Electrical Wiring / Questions
    Last Post: 15-02-2009, 03:41 PM
  3. Central Locking
    By caminsa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-04-2007, 02:49 PM
  4. central locking
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-03-2007, 06:32 PM
  5. Central Locking
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2005, 07:27 PM
