hi all, i have a vr series 2 and having some issues with my air conditioning and main engine fan, these issues are related because i can remove the ac compressor relay and the fans work normally
what i have done is this: removed the relays and swapped them around. the engine fan started to work but than cut in and out too quick and the temp just started to rise. the a/c clutch dose not kick in and the switch in side the car is on and working and all fuses are ok.
than i removed just the a/c compressor relay and the fans started to work normally but obviously no a/c operation
with all the relays back in and car running i removed the fan relay and found the a/c clutch engaged and worked fine than installed the fan relay and all was good. turn the car off and back on and the same thing happens again fan relay clicks like crazy fans have a fit and no a/c operation until i remove the fan relay and reinstall waiting for the a/c to kick in than is all good. also if i just remove the a/c clutch relay fans will work normally and the revs will jump up and down like if the a/c was working normally but the compressor doesn't work due to the relay being out
i have read somewhere it could be the pressure switch up the front, i unplugged it and the fans stoped and everything started to settle but i had no a/c due to the plug being unplugged.
any help would be good even if its a wiring digram.....
