Results 1 to 4 of 4
Thread: Rocker arm pivot bolt torque settings?
    vs Berlina
    Feb 2009
    Default Rocker arm pivot bolt torque settings?
    Hello can someone plz tell me the Rocker arm pivot bolt torque settings for a VR v6? i used the settings from a Vn book and i snapped the bolt.
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    VN and VR are both buick motors so I would assume that the torque figures would be the same for both of them. What may have caused you to snap the bolt is that they are a single use torque to yield bolt so they are supposed to be replaced each time they are removed as the yield strength is stretched and weakened each time they go in and out. I dont know VR figures but as a comparitive measure a VS V6 is as follows.
    Stage one: Tighten all rocker arm bolts down evenly to 11-19 newton meters.
    Stage two: Tighten all rocker arms down a further 90* sweep.
    VR Acclaim
    Sep 2008
    Kingsley WA
    Gregory's state (for VR):
    - First stage 12 - 18 Nm
    - Second stage +90 degrees
    The manual for a VS states: Rocker arm pedestal bolt torque 11 - 19 Nm, and a further +87 - 93 degrees turn angle.
  1. Head Bolt Torque Settings for VT Berlina
    By Missy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-12-2008, 05:51 PM
  2. torque settings
    By zedproject in forum General Discussion
    Last Post: 28-11-2008, 05:12 PM
  3. 8 Bolt flywheel/flex plate torque settings?
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-09-2007, 11:23 AM
  4. torque settings?
    By vk202 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-05-2007, 07:34 PM
  5. torque settings
    By atreyu in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-05-2005, 01:15 PM
