Results 1 to 8 of 8
Thread: vs speed sensor
    kittedvs's Avatar
    kittedvs is offline <---CHOICEVS
    executive t5 vs s2
    Feb 2009
    penrith nsw
    Question vs speed sensor
    hi, i originally joint j/c coz i have a vs which i converted from auto to manual it goes like a dream now but its just the speedo now i got that working using a diagram off an old thread but was just wondering dose it matter if it isnt conected to the ecu and will this affect my car in the long run. any sugestions or help would be great. TONY
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    You are likely to have problems with stalling when you clutch the car when pulling up at an intersection.
    You will also get the engine check light coming on unless you have disabled the auto in the memcal.
    muttley383
    kittedvs's Avatar
    executive t5 vs s2
    Feb 2009
    penrith nsw
    yer the check light dose come on now n then but it dosent tend to wana stall coz for sum reason the revs stay at 1000rvs for about 5 secs wen i pull up but not alll the time tho. is it possible it to be connected to the ecu wit auto comp remaped to manual?
    vs berlina
    Dec 2008
    i got mine done at morree...v6 conversions,,,send the comp n harness n it was like $300,comes back proper
    kittedvs's Avatar
    executive t5 vs s2
    Feb 2009
    penrith nsw
    yer but i gotta drive it to n from work so i only got weekends to do it + no rush it drives good enuff for now ill just do it wen rudd gives me $900
    VR Manual Wagon
    Mar 2009
    Quote Originally Posted by muttley383 View Post
    I am having the same problem with a VR auto To manual conversion. How do we disable the atuo in the memcal? Will this stop the stalling?
    Kev C
    muttley383's Avatar
    VR 383
    Sep 2007
    If you want to keep the original wiring loom and auto pcm the easiest solution would be Auto to Manual speedo solution
    You have to get the memcal modded to disable the auto trans functions.
    muttley383
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the vs ecu has a second input for manual VSS on pin D2 of the ecu instead of the stock auto location which is different for the different sensor wiring diagram is here on how to hook it up Rob's Creative Calibrations
  1. speed sensor?
    By VTPREDATOR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-12-2011, 05:06 PM
  2. speed sensor
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-02-2007, 12:37 PM
  3. HELP: No Speed sensor, what happens?
    By simc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-10-2005, 10:51 AM
  4. Speed Sensor
    By infernojs in forum Electrical Wiring / Questions
    Last Post: 24-05-2005, 05:37 PM
  5. Speed Sensor
    By vk_calais in forum Electrical Wiring / Questions
    Last Post: 07-03-2004, 09:24 PM
