Page 1 of 3 123 LastLast
Results 1 to 25 of 69
Thread: Too lean on one bank
    VS II Ute V6 1996
    Jan 2009
    Lake Macquarie NSW
    Default Too lean on one bank
    Hi all, I checked my spark plugs yesterday, and found that all three on the right bank were very white, way too lean a mixture it looks like. The ones on the left hand side looked fine, a brown colour.
    A few years back, I had the car at a Holden dealer to have it checked out for a problem with it idling too fast, and the auto shifting hard. It would not play up while they had it, but they did find an unrelated problem. I was told the only error they could find was with the right hand oxygen sensor. I was told it was a ‘bit lazy’.
    I hadn’t noticed any problem until now. What I would like is other opinions on this. Does it sound like I need to replace the oxygen sensor? Or could it be something else?
    I think new would be best for a part like this. Or are they usually reliable, would one from a wrecker be OK?
    I think having too lean a mixture would cause it to be getting too hot at combustion. I think this could hole a piston crown???
    Any advice would be much appreciated.
    Thanks, Chappo.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    whats the fuel consumption like? was it the drivers side bank that was showing lean? possibly a vacuum line that has come off under the TB. this is a common problem. check for fault codes and see what that shows. if nothing else fixes the the problem then you can try cutting the wire for the heater in the O2 sensor, drivers side. if that doesn't work then possibly try a new sensor. don't get a used one. there is a wiring design fualt with the O2 sensors on the VS that effects the drivers side sensor. cuttingth epink wire is a quick fix. also try cleaning the 2 earth points under the DFI module where the sensors are earthed
    Body by Holden, Soul by Brock
    the Legend will live forever
    VS II Ute V6 1996
    Jan 2009
    Lake Macquarie NSW
    Thanks Immortality. It is on the driver’s side I have the problem. I have not noticed any change with fuel consumption.
    I will check for error codes tonight, and look for any vacuum lines that have come off. I’ll report back what I find.
    Very interesting about it being a wiring design fault. What is the drawback, if any, with the quick fix of cutting the pink wire?
    Thanks for the help.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    VS II Ute V6 1996
    Jan 2009
    Lake Macquarie NSW
    I have checked for error codes and got two error codes:
    Code 76 - Air/Fuel ratio variation between left and right banks
    (which I already knew )
    Code 97 - Canister Purge Solenoid and/or Circuit
    The only canister I know of is the one near the driver’s side headlight that has something to do with collecting engine fumes for sending back to the fuel tank. I don’t expect this would be causing the lean running on the driver’s side cylinders.
    I cannot see any earth points under the DFI module, which from what I have read is the plate that the coils are mounted on. Please correct me if I am looking in the wrong place here.
    I have two brown wires, a white, and a purple wire going to the O2 sensor, I assume the pink wire mentioned would be the purple one I can see. Not sure if I should cut this, or try a new sensor. If it is a wiring fault causing this, then if I buy a new one, the fault will still be there.
    Do you think I should cut the purple/pink wire and see what happens?
    Should I worry about the code 97?
    Thanks heaps, Chappo.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    purple will be signal to ecu browns will be heater power and earth white 02 signal earth if fixing the earths or cutting the heater wire doesnt help ide say the sensor is getting stuffed on the side that is richer plugs should be very clean and white
    VS II Ute V6 1996
    Jan 2009
    Lake Macquarie NSW
    Thanks for the help guys. I'll get two new sensors I reckon. I won't bother cutting any wires, at this stage.
    Apr 2006
    Auckland NZ
    the pink wire is in the main loom so you will need to see what it turns into for the O2 sensor wiring (i think it's one ofthe black wires). i'd suggest cutting the wire first and see what happens. others have tried now O2 sensors that have worked for a short time but then also fail.
    don't worry about code 97 for now
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Quote Originally Posted by Chappo_1 View Post
    Mate that is for a vr.
    Here is pics for vs.
    Should explain everything.
    There on two studs one is located at the front of the engine block that clearly visible its located just south of the water out/in? larger hose joint for the heater and the other is located near the loom for the passenger side O2 sensor its the bolt on the back of that head... make sure to clean both the connector and the mating surface thoroughly and also the wire thats clamped to the connector..
    Attached Thumbnails Attached Thumbnails Too lean on one bank-earthing-point-back.jpg   Too lean on one bank-earthing-point-front.jpg
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    They are not O2 sensor earths, the sensors earth back to the ECU on the VS, they are just common earths. The sensor earths may pick up on them but they go all the way back to the ECU.
    Also, it is probably mentioned in the thread SW linked to, but the O2 problem is not an earth problem. It is a heater problem. You get some voltage leak from the heater wire to the signal wire and this will affect the voltage that the ECU picks up from the RH sensor. I don't know why it only happens on the RH one, but it is a known fault by Holden and cutting the pink heater wire on the loom side of the RH sensor plug fixes it.
    Visit my Facebook page
    Apr 2006
    Auckland NZ
    Quote Originally Posted by Not_An_Abba_Fan View Post
    those earths are for the ecu. the ecu has multiple earths on the block. the O2 sensor problem is related to the wiring design of the earthing of the Heater for the RH O2 sensor it is connected to the O2 signal earth (they share a earth connection and this is where the stray voltage occurs). this is the primary fault. the correct fix is to actually alter the wiring at the ecu, the simple fix is to cut the pink wire at the sensor. i have linked to a wiring diagram in one of the other threads that clearly displays the wiring of the O2 sensors.
    VS_Pete_1's Avatar
    Dec 2007
    So Abba.
    What are the pics of then I would like to know thanks mate.
    I would like to learn something.
    We need pics of ECU the sensors earth back to the ECU on the VS, they are just common earths. that u speak of please.
    Got any mate please?
    I don`t want to give wrong info to other members.
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    The earthing points pictured fixed my problem of it running rich, but yours sounds like a different probleem all together.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    found it
    here is the wiring at the ECU, if time permitts, i'll be doin this on the weekend
    Attached Thumbnails Attached Thumbnails Too lean on one bank-vs-20v6-20oxysensors.jpg
  15. #15
    VS II Ute V6 1996
    Jan 2009
    Lake Macquarie NSW
    Thanks for all the help and advice fellas, especially for the pics Pete.
    I will clean these earth points up, and cut the pink wire to the RH sensor. I'll check the plugs again at the same time. I haven't looked at them since I cleaned them up last Sunday. It has idled a little roughly somtimes when I have started it this week, but it idles OK once it warms up.
    I'll reset the error codes, and then check for codes, and the plugs again after a couple of days.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Here is the wiring diagram that shows where the O2 sensor wiring goes to the PCM.
    http://www.memcals.com/pdf/VSV6%20Au...%20Diagram.pdf
  17. #17
    VS_Pete_1's Avatar
    Dec 2007
    Thanks for that Abba.
    Sorry if it seems I was upset with you I was not.
    I got my info from here and thought it was right.
    I like to give right info to help fellow Members and hope I get it back.
    Peter.
  18. #18
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i have been getting codes:
    Code 65 - LH Oxygen Sensor Rich (O2)
    i've just finished earthing my o2 sensors at the ecu, cleared the codes, and will monitor this over the coming weeks. I'll end up doin a how-to after i see how it goes.. i have a full tank of fuel and only the open road ahead. will keep everyone posted. i might invest in some new o2 sensors over the weekend. but will see if anything improves with just the earth fix.
  19. #19
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Will be interesting to see the results.
    VS_pete_1, no dramas mate, I like to help too.
  20. #20
    VS_Pete_1's Avatar
    Dec 2007
    Quote Originally Posted by ephect View Post
    A How-to-Do will be great. (with pics)
    Looking forward to it.
  21. #21
    VS_Pete_1's Avatar
    Dec 2007
    Sweet Mate.
  22. #22
    VS Calais Series II
    Feb 2009
    Hi dude,
    i had really bad fuek economy. Changed 02 sensors, then got code 76 - variation in air fuel ratios between left and right banks. and noticed 1 side was rich one was lean.
    Since the 02 sensor change i also cut the pink wire and cleaned all ground points. Flushed radiator, injector cleaner (whole bottle) not half, spark plugs and going to change leads.
    Car runs alot smoother and fuel has improved alot.
    You might want to try a few things. I noticed the injector cleaner did a hige difference, if you haven't used a cleaner for ages try it, it really helps.
  23. #23
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    The only problem i can see with changing everything at once, you dont know what actually fixed the problem. but its good to hear that you have ur problem sorted. what earth points did you clean?
    I have changed my injectors with new ones about 3-4months ago and run injector cleaner thru it every 6months.
    cutting the pink wire is a simple fix instead of repairing the faulty earthing problems at the ecu from when they rolled off the production line.
  24. #24
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    ok, well its been just over a week and so far i have the same fuel economy as before, havent checked codes yet to see if im getting any codes logged, but my air/fuel gauge has been showing me constant results and currently im running rich.
    i'll purchase some o2 sensors this week and whack them in.
    will check codes shortly and post back up.
  25. #25
    VS_Pete_1's Avatar
    Dec 2007
    Thanks mate for the update.
  1. VK Bank Scoop Question
    By thakillav8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-12-2008, 01:39 PM
  2. miss firing on one bank?? help
    By potshots007 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-08-2006, 07:30 PM
  3. When you get payed to your bank account..
    By TehFastyOne in forum The Pub
    Last Post: 16-10-2005, 09:22 PM
