Results 1 to 9 of 9
Thread: VS V6 losing oil pressure
    VS Statesman
    Feb 2009
    Default VS V6 losing oil pressure
    Hoping someone can give me feedback. I have a VS Statesman V6 and am having trouble with the oil pressure. Basically, after driving or idling for 2 minutes, the oil light comes on and it loses oil pressure. The engine begins to get noisy and I need to turn it off.
    My mechanic has tried engine flush treatments, two or three times, no luck. I have spoken to other people and they have said it could be heavily sludged up internally and may need to be dismantled and rebuilt. I was wondering if someone has had this problem before and may be able to help. The car has done 178K km's and regularly serviced.
    It may be a coincidence, but the problem started straight after I picked the car up from the mechanic's after being detailed, to sell. The engine was cleaned down, is there some setting in the computer that might have gone haywire?
    Will appreciate any feedback.
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    If it was in the engine management, I wouldn't have thought it would make the motor noisy. But still, i'd try replacing the oil pressure switch. It's only about $20 for a genuine one and 10 minutes work to replace. The oil pressure switch kept bringing the oil warning light on when I had my VS, but it didn't get noisy.
    Whoever said 'There is no substitute for cubes' had obviously never heard of Jet power
    VZ SV6
    Oct 2008
    Newcastle NSW
    Some mechanics are retards and try to put things like 0W-30 in a commodore specifying 20W-50 (its racing oil, better right? *rolls eyes*)
    It made my oil pressure light flicker ever so slightly under heavy acceleration (just before it changed gears).
    VS Statesman
    Feb 2009
    Thanks for the comments. We replaced the oil switch and still no luck. After the light comes on the engine get noisy and the temp raises, as well as, loses power. If I was to keep driving I really think the motor would seize!! I think it might be time for a new engine.
    While I'm at it, will a V6 out of a VX fit the VS?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The oil pressure relief valve may be blocked open - this will drop the oil pressure once the oil warms slightly...hydraulic valve lifters will then collapse due no oil pressure causing noisy engine and reduced power due to valves not fully opening.
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    blocked oil strainer happened to my mate.
    possable solution: using an orbital sander to vibrate the sump to sonic clean the oil pickup, this worked and hasent said anything bad to date.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    double post
    Powered By Garrett
    VS 3.8l Exec
    May 2006
    Ya mums house!!!
    3.8 VR Executive S2/ Kawasaki zxr250
    Aug 2008
    West Auckland NZ
    could it be the oil pump crapped out. my vr did the same.
    i can say one thing though if you want 2 keep the engine dont keep driving it. I managed 300ish ks of thrashing the balls off it before ith threw a bearing... right out of the side of the block.
    Federation
    Against
    Rotary
    Tossers
  1. VR losing coolant??
    By gontix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2009, 07:50 PM
  2. Ecotec losing oil
    By Philthy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2008, 06:35 PM
  3. Losing licence in SA
    By albert5268 in forum The Pub
    Last Post: 27-03-2008, 09:07 AM
  4. Losing Power
    By AdamAnt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2007, 12:58 PM
  5. How much are you losing a year?
    By daveb8 in forum General
    Last Post: 22-03-2006, 11:15 AM
