Results 1 to 15 of 15
Thread: 95 VS cooling problems
    vs bt1
    Jan 2009
    Melb, VIC
    Default 95 VS cooling problems
    hey guys,
    driving my car for the 1st time in a while last nite and it overheated. its never overheated on me. then got home same again. but i found out that the temp gauge isnt working. can anyone shed some light. possibley be the thermostat?
    ben.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The thermostat should not affect the temp gauge which will be an electrical problem (unless the cooling system was bone dry). What were the symptoms of your overheating -i.e. boiled etc? and was the system low on coolant.
    vs bt1
    Jan 2009
    Melb, VIC
    yeah boiled. its was over 3/4 full. i had just picked it up.
    i am currently having electrical problems - 95 VS fuse problems...?
    Could those current electrical problems be affecting why my temp gauge is not working?
    thankyou, ROLLA.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    why only 3/4 full ? your radiator coolant should be full to the cap, always !! also make sure your thermo fan is switching on when the temp gauge reaches half way.
    vs bt1
    Jan 2009
    Melb, VIC
    well the thermofan sorta "chooses" when it wants to work. but i cant tell you if it goes off off halfway on the temp gauge because its not working.
    VS l67 statesman
    Dec 2008
    when your temp gauge doesnt work,low coolant is always the first thing you check ,it will even cause a false gauge reading & make your thermo fan operations unpreditable ,try bleeding the system if it is low or has been dumping a lot
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds like you're having electrical mayhem!. With the thermofan I'd try hotwiring it so it runs all the time to solve your boiling problem although you say it chooses when it wants to work which is pretty much the way its supposed to...as long as it chooses the right time to switch on which it sounds like it isn't. When you say it was 3/4 full do you mean the overflow coolant reservoir tank or the actual radiator?
    Re the interior light - someone hasn't turned it to the "stay on" position?
    VZ SV6
    Oct 2008
    Newcastle NSW
    the temp sender wire connector may have come off at the inlet housing, quite easy to accidently do when removing the belt etc.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    The coolant temperature sensor is used to determine whether or not to switch the fans on. A separate temperature sensor is used to pass the temperature signal to the gauge on the dashboard. As previous posts have suggested, you need to ensure that the coolant is at the correct level (between half and full on the overflow tank), you are using the correct grade of coolant - 50% water, 50% ethylene glycol (genuine Holden coolant is best ), and that the cooling system has been bled properly.
    Oops, just read the BT1, Holden V8 engines automatically bleed the air from the cooling system. You just need to keep topping up the overflow tank for a couple of days after you change the coolant.
    vs bt1
    Jan 2009
    Melb, VIC
    ok, thermostat was shagged. has been replaced and bled.
    but.... thermo fans DO NOT WORK. driving, stationary, nothing.
    all plugs are in, relay is good.
    also the temp sender cable that runs to the gauge does not work, and neither does the gauge (temp).
    what else could be wrong? i've checked all the earths, and connections.
    VB SL/E
    Dec 2008
    Is it getting hot enough?
    My VR shows nothing under 60deg and fan only runs with A/C on unless hot enough.
    vs bt1
    Jan 2009
    Melb, VIC
    yes, it is way more than hot. all level's are good.
    and yes, tried it with aircon and still, nothing.
    mxmark is offline vs2dy4
    Vs acclaim (ecotech v6)
    Mar 2009
    Wangaratta
    is there any way of adjusting when the fan kicks in. Because mine gets up to near 3/4 before its kicks in. ive had the fan controller and thermostat changed over.
    VB SL/E
    Dec 2008
  15. #15
    Aug 2004
    Quote Originally Posted by lo-rolla View Post
    Have you checked your fan relays and fuses? Swap with another similar size relay (for example the horn relay) and see whether that solves your problem.
LinkBacks (?)
  1. VN Cooling System problems
    By VNHeartache in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-09-2008, 09:26 PM
  2. Low Temperature Cooling Problems
    By Lush in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-08-2008, 09:28 PM
  3. Cooling Problems
    By lilzen96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2008, 07:35 PM
  4. VP Cooling problems and stalling
    By mustapha in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2006, 10:38 PM
  5. Cooling Problems
    By lukeVKCOMMY202 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-02-2004, 08:14 PM
