Results 1 to 11 of 11
Thread: car problem
    vs commodore
    Feb 2009
    Default car problem
    hey guys
    i own a 96 vs commodore auto and iam haveing trouble with it i will explain exacly what i have done and whats happening
    i brought the car abouth 3 weeks ago and everything was fine untill 2 days later i was working on my car and left the cd player going without car being turned on and the battery went flat... i called a mate and got it jump started and took it for a 10 min drive and brought it home everything was fine.. i drove it for the next 2 days then one morning went to start it and it was makeing the sound of a flat battery again i took battery out and took it to battery world sydney(battery spec) he did some test and said the battery was ****ed so i brought a new battery and put it in the car at first it wouldnt start so i had to jump start the new battery took it for a 5 min drive as i was driveing i turned stereo on and a/c and headlights and the cd player started cutting in and out and then a/c would shut down and start up again and high beams would go dull then bright i brought car home and turned it off went to start car again and it wont start
    when i turn car on accesiors now cd player wont light up when i turn the key to start it it doesnt even make any noise at all
    any help on what it maybe iam tottaly puzzled and would be hapy if someone can help me
    ryno_vrx's Avatar
    ryno_vrx is offline Donating Member
    VR HSV enhanced Berlina
    Nov 2008
    Mirani
    vs commodore
    Feb 2009
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    doubt they would have done that.
    i have bought many a battery from Battery World and each and every time, they test the battery in front of me to make sure its a good one.
    Id say your Alternator is not working and you have killed the battery yourself.
    Battery World have done the right thing (even though it isnt their responsibilty if you killed the battery) and have replaced it for you.
    you can either replace/fix the alternator or leave it and see how long before this battery is dead as well.
    Commodore VS series 2 S pack
    Jan 2009
    Laurieton NSW
    alternator without a doubt mate cuz ur alternator charges ur battery and if its not working then all ur accesories , A/C / stereo n so forth start running of ur battery which flattens ur battery so yeha id get that checked
    VRII Acclaim
    Jul 2005
    I would investigate further to. You will need a multimeter to check the battery voltage while the car is running to see if the alternator is charging the battery. It could also be your starter motor on its way out.
    The guys at the battery shop will load test the battery. This doesnt charge the battery first. A discharged battery will show up as no good, even though it is still a good battery. Its just that its already flat. Thats my understanding anyway. You shouldnt need to jump start a new battery.
    vs commodore
    Feb 2009
    i did the check with the alternator and had auto electrician out today he sadi alternator is fine and its the battery thats not good
    i didnt buy battery from battery world i got it from a reconditioned palce its a second hand battery
    StockoVRWagz's Avatar
    StockoVRWagz is offline Formerly White50L
    '94 VR Wagon
    Feb 2008
    Northern Suburbs, SA
    Quote Originally Posted by aussie_soldier View Post
    second hand battery
    Save yourself some time and buy a brand newie. I got one to suit my 5.0L from sprints for less than $100 I recon. Replace your terminals as well if they are crappy, they aren't much either and check/change Voltage regulator is also less than $100 I recon.
    I know you said its all good, but these might be things to look at if you have problems in the future. Hope it helps
    Nov 2003
    Warrnambool
    well, from the way you wrote it, it sure sounds like you bought a NEW battery from Battery World in Sydney.
    vs commodore
    Feb 2009
    Quote Originally Posted by davway View Post
    well sorry sir but i didnt say i brought it from battery world
    so iam ok now car is flying as it was before this
LinkBacks (?)
  1. 28-02-2009, 04:14 PM
  1. vr ss lpg problem
    By genkibobo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2008, 12:54 PM
  2. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  3. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  4. vs problem
    By itchy pits in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2006, 11:26 AM
  5. VN problem
    By VNPOWER in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-05-2005, 07:18 PM
