Results 1 to 13 of 13
Thread: How to change idle on 5L
    pedrotski's Avatar
    pedrotski is offline Big Stato!!
    95 & 96 VS 5L Statos
    Jan 2008
    Mandurah
    Default How to change idle on 5L
    Hey guys. How do you change the idle on a 5L v8.
    I have only been able to change idle on cars from the 70's etc lol. I have no clue on where i can adjust it.
    Thanks in advance.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Yer, but he said V8 (dizzied) not V6 (DFI)
    Adjust the throttle cable!!! and take out some slack via the two nuts on the mounting plate to bring it to 850rpm/900rpm.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the IAC controls the idle and is controlled by the ecu adjusting idle any other way is just asking for problems!!!!!!
    VP Executive R-spec
    Jan 2005
    If it's stock and not idling at the right speed there's something wrong with it that's about as black and white as it gets. The IAC might not be working or the timing might be out etc
    pedrotski's Avatar
    Jan 2008
    Mandurah
    I want it to idle lower. I dont see why it has to idle at 700 rpm.
    If i changed it to 500 what problems would i run into.
    The reason i want it lower is because i just like a lower idling v8.
    VP Executive R-spec
    Jan 2005
    About 650 is stock your tacho is out 50 rpm (better than most). 500 rpms would be doable but it might be a bit wonky running that low
    pedrotski's Avatar
    Jan 2008
    Mandurah
    Quote Originally Posted by greenfoam View Post
    I don't really know, I just took that number off my head haha. When i took it for the major 300,000km service at holden they reset it. I liked it better lower
    vr statesman 5.0 + vs exec s2 auto
    Mar 2006
    central coast, nsw
    Smile
    why cant you just back off the little throttle stop adjusting screw on the top of the throttlebody. its usually got a green plastic cap on it. take ya air intake pipe off between airbox and throttlebody, and with engine running place finger over the hole for the pvc hose, hole is just inside throttlebody opening. then while ya finger is sealing the pvc hole the engine rpm will drop , then back off the little throttle screw till ya engine is just ticking over without stalling . when ya take finger off the pvc hole you will hear the engine make a helluva sucking noise and rpm will rise . after a few seconds engine rpm will settle . this is how you set the base idle , no good if you idle any lower than this. just make sure you adjust ya throttle cable first, so its not too tight or too slack.......cheers.
    VS Clubsport series I, VY II R8 Clubsport
    Jan 2008
    Sunbury, Victoria
    I did that to my Clubby the other week, I actually picked up the revs on mine a bit, that screw works for sure but the IAC solenoid will adjust the RPM back to around 800 RPM roughly after a few seconds. The screw lets the throttle plate stay cracked a little, and it made mine run a lot smoother (I only moved it 1/4 turn mind you).
    Rich
    pedrotski's Avatar
    Jan 2008
    Mandurah
    Quote Originally Posted by richo7502000 View Post
    Rich
    What do you mean stay cracked?
    Jan 2008
    Sunbury, Victoria
    I mean that the throttle plate (butterfly) inside the throttle body stays partially opened (or 'Cracked') by a little more than usual. It will never be fully closed at Idle but it will come very close. By adjusting the throttle stop screw it adjusts the butterfly open more or closed more depending on how you turn the screw!
    I hope that cleared up what i was saying???
    cheers
    Richard
    VP Executive R-spec
    Jan 2005
    The screw on the throttle body is just to setup the blade, the IAC will still set the idle to where its set in the tune (unless you've gone out of it's range with the screw or the IAC is broken). It's not a idle screw
  1. Vt rough idle after headgasket change
    By pickletime in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 10:26 AM
  2. ute missing when idle plugs and leads change
    By willy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2007, 06:26 PM
  3. Low idle?
    By defyet in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2007, 09:35 PM
  4. Oil Change/filter change interval on VTII 6 cyl ?
    By nmldb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-06-2006, 04:26 PM
  5. Bad idle 5.0
    By Richoss in forum General Discussion
    Last Post: 15-04-2005, 10:49 AM
