Results 1 to 7 of 7
Thread: VS cut out now won't start
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Default VS cut out now won't start
    I was driving along and my engine hesitated and i heard a little "bleep" noise and some lights came up then the engine stalled. It restarted fine and i got home, put it in park and it stalled again. Now it won't start at all, no lights on the dash, no fuel pump. Nothing at all.
    Any ideas?
    VS 3.8l Exec
    May 2006
    Ya mums house!!!
    Hey Mate,
    Dosn't sound good, but i would start by looking at the errors codes that are logged, there's a how to section you should check out first, once you have something to go on let us know...
    As it is now what your describing could be a large number of issues.
    Good luck mate!
    Dec 2008
    Just had NRMA out. They said there's "no accessory feed to (through?) the ignition" and that it's an auto electrician job. I know how to check for error codes but how would that work if there's no dash lights?
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    check your main fuse it may have blown, or even check the feed wire coming from the alternator
    Dec 2008
    96 VS II Acclaim
    Dec 2007
    Quote Originally Posted by maldotcom2 View Post
    Got it fixed. It was a burnt out wire connection on the alarm.
    Did you find out why the wire burnt out in the first place?
    Coz if you didn't it might burn out again.
    Dec 2008
    The auto electrician said it was one of the wires in the alarm (aftermarket) that carries a lot of current, and it doesnt take much to burn them out. He put in a much bigger connection so it won't be a problem anymore.
  1. doing up my vs.. where to start?
    By Riles89 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2008, 01:17 AM
  2. where to start ?
    By VT_WA in forum Projects
    Last Post: 09-01-2008, 04:22 PM
  3. VK won't start
    By Rod F in forum Electrical Wiring / Questions
    Last Post: 01-02-2006, 01:47 PM
  4. Won't start without "start ya bastard"
    By Steven M in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-11-2005, 12:12 PM
  5. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
