Results 1 to 8 of 8
Thread: ??removing indicators??
    vr executive
    Nov 2008
    Default ??removing indicators??
    hey guys i just bought clear oval indicators for my vr and i cant get the old ones on the side? how do i get them off
    cheers jordan
    hsvpunk's Avatar
    hsvpunk is offline volunteer firefighter
    vy ss II M6
    Jan 2007
    Mornington, Vic
    they should unclip from left to right. and then clip in from right to left.
    If it is getting abit stuck, try a bit of fishing line on one corner of the old sqr one.
    ( do that from left to right, so it slide the weird clip thing )
    dont worry, il start a ride thread soon.
    96 VS & 5spd VT 5.0L VX Clubsport lookalike
    Jun 2008
    Port Macquarie/Newcastle, NSW
    be careful not to drop the wiring into the guard as well ...bitch to get out
    VR Equipe II
    Mar 2008
    QLD
    Quote Originally Posted by dbarnes View Post
    haha yeah i did it.. woops.
    VS 3.8l Exec
    May 2006
    Ya mums house!!!
    speaking of indicators, what about the removal of the idicator assembly from the headlight?
    do you need to remove the entire light assembly or?
    Sorry for highlacking thread, but i figure it's a valid indicator question also
    '97 VS Commodore + '98 E36
    Apr 2005
    so you want to remove the front indicator??
    if so you will need to..remove the front bar first and then find the bolts that hold the headlight in and unscrew the indicator assembly off the headlight.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    easiest way is stand facing the rear of the car. Grab the 'rear' of the indicator, and pull outwards and to the front at the same time, and they will clip out. Put the other back in the same way, the 'front' part of the indicator first, then push in at the rear.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    GAMBLR's Avatar
    GAMBLR is offline More trouble than u think
    '04 VZ Calais LS1
    Dec 2006
    Whyalla (yawn), South Australia
    Stealthy has got it spot on. look in the manual if you get stuck after that, under replacing globes
    CruznCalais
    [GAMBLR]
    The VZ is here! About time!
  1. Indicators
    By Bubbles in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-04-2007, 12:23 AM
  2. Removing side indicators for a VS
    By Sphinx in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2006, 08:55 PM
  3. Indicators
    By sicko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2006, 10:48 PM
  4. Indicators
    By Jules86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-05-2006, 05:30 PM
  5. removing indicators
    By t-rev in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-05-2005, 02:33 PM
