Results 1 to 7 of 7
Thread: VS Auto....tansmission or tail shaft????
    vs s2 equip
    Feb 2009
    Default VS Auto....tansmission or tail shaft????
    Hey all and thanks in advance....
    I have an auto vs series2 for a while now it has been shuttering in drive up hills i have been dropping back into 3rd and its a bit better someone told me its not my trans its my tail shaft some uni joint or something???? any ideas????
    cheers.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    vs s2 equip
    Feb 2009
    Set of thongs
    Dec 2005
    Stonedville
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    wipe the oild on a paper towl, if its still clear u either have water in there..... or maybe synthetic type oil in there??? or some weird ass oil haha
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd check your ignition system first as your symptoms sound more like missing under load than a transmission problem (and a lot cheaper to fix!) - I'd replace the plugs and leads if more than a year old and make sure the leads are pushed onto the coils and plugs properly. Good Luck.
    alipete's Avatar
    alipete is offline Ban Speed Camera's
    VS Executive
    Jul 2005
    The vs was renound from new with a shudder partiulary in 1st under hard acceceration and there is nothing you can do.
  1. vn auto tail shaft same as vs?
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2008, 12:35 AM
  2. VN/VP Manual and auto tail shaft
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-03-2008, 08:11 PM
  3. tail shaft length manual & auto v8
    By nathans1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-11-2006, 08:32 PM
  4. Vl Commodore 87 Auto Gearbox And Tail Shaft For Sale
    By alarna in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-08-2005, 07:23 PM
  5. auto, tail shaft or diff???????
    By spacattack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-03-2005, 09:15 PM
