Results 1 to 11 of 11
Thread: Steering problems
    None ATM
    Nov 2008
    Default Steering problems
    Hi guys,
    Have a VS drove up a gutter in the rain the other day flattened the tire. As I only bought the car and it had some tyre wear I decided to replace all the tyres.
    I had a wheel alignment and the car is ****ed, it is driving like shit so I took it back they made me feel really bad for bringing it back and reluctantly re-did it.
    Still shit! it is very jurky in the steering, almost feels like the steering is balancing on a point and and small movements wants to fly off in the direction of the turn. feels like one tire is gripping more than the other around corners.
    Just 100% shit to drive.
    Anyone able to explain these symptoms, and even elaborate on the symptoms one would see with toe in and toe out etc etc
    Cheers guys.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It's possible your problem lies with the steering rack...possibly the rack has been bent or otherwise damaged - however if you had a full wheel alignment done....toe-in, caster and camber plus a test drive then the technicians should have reported that there is still a problem.
    I'd jack the front of the car up on stands so that you can turn the steering from left to right and see if it is smooth in operation. If it jams or jumps or whatever then the problem is probably in the steering rack.
    Probably your best bet after the above mentioned test is to take it back to where it was aligned for their advice.
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    how hard did you hit the gutter?
    Could be worse and the whole strut housing could be bent
    None ATM
    Nov 2008
    Hit it fairly hard.
    It was pissing down rain and the gutter looked like it was further away and bam.
    car jumped straight up on the gutter was a decent height too. Hub cap flew off into a shop.
    Was a beautiful car before that happened.
    Had a bit of noise in the rack but it steers like shit now
    VS Calais Series II
    Feb 2009
    Well id think a tyre pro will find a potential problem with the steering, i cant believe they haven't picked anything up.
    Where did you go, is the place well known???
    Try take it to a mechanic to have a look over and see what he finds you could have damaged a few things.
    None ATM
    Nov 2008
    I went to a holden dealer for the alignment. And they were the most unhelpful people I have ever dealt with.
    I really don't want anything to be bent. I would like to have a look myself but I am not really sure how to find the problem. I do most of all work myself as I don't trust mechanics as they never seem to do the right job and charge a fortune.
    Any hints on knowin how to tell whats bent. Nothing looks bent it all looks good the rim didnt even get damages and nothing is visually dented or bent.
    The alignment shows up ok but there are a few figures on the alignment I am not familiar with.
    VS l67 statesman
    Dec 2008
    I heared of bent suspension arms before ,have you checked this ? and how are the bushes and bearings?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by Keeffe View Post
    Can you explain further what the noise in the rack sounded like and when was it happening.
    The other thing to consider is that previous to the 'accident' the alignment may have been out causing heavy steering. After the 'accident' you fitted all new tyres and had an alignment done. It is not unusual to find the steering 'light and twitchy' when new tyres have been fitted plus its possible that the alignment was out previously making the steering heavy and unresponsive.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    could be:
    bent control arm
    bent strut bar (radious rod)
    stuffed suspesnion bushes
    wheel bearing
    tie rod end
    ball joint
    crossmember
    strut
    strut top
    but seeing as you took it to holden or even a tyre place etc they are supposed to check teh front ends and make sure its in workable condition before carrying out and work...well thast what they do here anyway
    realistically your best bet is to either jack it up and check all suspension for movement or take it to a reliable suspension place...or for shits and giggle take it to pedders for the $14? safety check
    None ATM
    Nov 2008
    Went to pedders today they threw it up on the aligner.
    The alignment was out terribly Thanks genuine holden dealer.
    The guys at pedders Ballina let me watch and they had to do the alignment twice as the wheel was not centered. They let me set where I thought centre was.
    So the camber is out a bit so for my 96 commy with 140k on it it will be all new shocks nolathane suspension upgrade kit and a new rack.
    Anyone know where I can get a good reliable remanufactured rack?
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Its hard to know if your getting a good rack, alot just have new seals whacked in and sent back to the shop for exchange and others are actually properly overhauled. You probably need to talk to the person at the counter of the shop your at to see if they can tell you what gets done with their overhauls
    Reaper
LinkBacks (?)
  1. Power Steering Problems
    By Helicopter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-05-2008, 12:06 PM
  2. Steering problems
    By stockies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-09-2007, 08:04 PM
  3. Steering problems
    By andrewmac in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2006, 01:08 PM
  4. Steering problems?
    By cladiges in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-04-2006, 09:31 PM
  5. VL s2 steering problems please help
    By Slash187 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-01-2006, 08:36 PM
