Results 1 to 3 of 3
Thread: Locking is the Central Issue...
    VS Statesman
    Feb 2009
    Default Locking is the Central Issue...
    Hi all,
    I have a VS Stato that I have had for a year and a half now and ever since I bought it the drivers door is the only one to operate on the key remote. Which is strange because when I lean over to open the passenger door the actuator in the drivers door operates as well. Another annoying thing is that this actuator has started carrying on like a machine gun just about every time it operates. I have the door apart at the moment and have been poking about with a multimeter and the holden workshop manual but have not been able to sus out the cause of the problem. The same thing happens with the back doors too, when they are operated the drivers door carrys on.
    Any ideas?
    Richard.
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    you can try simply adjusting them (pushing pulling and wiggling....!). If the drivers door actuator only works spasmodically then it is either not quite extending as far as it should or it's stuffed.
    If it's stuffed a new pack of them is about $40 and you'll have bits left over.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    they can all just be seized. I have seen quiet a few where people go to replace them and they simply just need freeing up again. If when you push the button can you just see the lock move a tiny bit. If so then there is power there and you just need to see why they arnt moving because they are not a very strong actuator. The 2 rear doors have guide rails and links that may all be seized up too. So check all that out before you go to deep into things.
    Reaper
  1. Central locking issue
    By muggo05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2008, 01:57 AM
  2. Central Locking Issue
    By AL'sVY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-10-2007, 11:24 AM
  3. Vr Central Locking Issue
    By vrbenno in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-05-2007, 06:07 PM
  4. Central locking Issue
    By vincent49 in forum Electrical Wiring / Questions
    Last Post: 07-02-2006, 07:51 PM
  5. central locking issue
    By Insanesinner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-12-2005, 09:32 PM
Tags for this Thread
