Results 1 to 5 of 5
Thread: boot wont lock
    vr berlina
    Aug 2008
    Default boot wont lock
    my boot wont loack atm so it is constantly open, just wondering where i would need to take it to get fixed, to holdens or to a locksmith?
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    push the lever on the side of the seat down and try again. make sure the tongue the boot loacks onto is central. if the boot locking mech is dead, just go to a wreaker and slap on a newie from there , shouldnt cost more than 5 bucks . shouldnt need to change the keyed lock its self
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    yeh as above, try lifting the lever as far as you can, then FLING it down (dont just lower it).
    Good luck!
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Had the same problem with my boot - in the end I removed the latch assembly and drilled the rivets out to find that a spring which does the latching was broken. Found a similar spring in my junkbox and reassembled. Had to weld the latch assembly shut as it's not designed to be pulled apart so I'd recommend going to a wrecker. To remove the assembly is simple and just a few screws.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Check your boot rubbers are all in place and none of them are stretched into the corners (if that makes sense?). I was chasing the same problem all last week, till i pulled my boot rubbers off to dry them and when I put them back on it shut properly and even the cable release worked.
  1. vn boot lock
    By TheStateo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2007, 12:33 AM
  2. bonnet wont lock shut
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2007, 07:00 PM
  3. replacing boot lock
    By flyen in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-03-2006, 09:38 PM
  4. wtb boot lock for vl with key
    By pro1438 in forum Swap / Wanted to Buy / Trade
    Last Post: 12-02-2006, 10:14 PM
  5. VT boot lock
    By tc0707 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-09-2005, 02:44 PM
