Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: is it the ecu
    VR Executive S1
    Feb 2009
    cairns
    Default is it the ecu
    hey i need help, i just put a peformance chip in my vr now it wont go over 2000 revs and wont change gears. The speedo is also now not working.
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    did u remove the chip yet?
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
    VR Executive S1
    Feb 2009
    cairns
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    put the stock one back in and reset the ecu by dissconnecting the battery negative and wait a minute or so and plug it back on see if it comes right ide say you have the wrong kind of chip or its a dodgy one.
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Hopefully when you put back the stock one, it will all go back to normal, then: Contact the seller.
    Current Issue(s)
    N/A
    в∞ѕтεכ √&
    Jul 2008
    NZ
    VR Executive S1
    Feb 2009
    cairns
    в∞ѕтεכ √&
    Jul 2008
    NZ
    and it runs ok just the speedo doesnt go and it wont change gears.check error codes the speed sensor may have gone funny if it happened when you put the chip in you did disconnect the power to the ecu by dissconnecting the battery when changing chips each time
    VR Executive S1
    Feb 2009
    cairns
    yea i disconectid the battery every time and it runs fine until you drive it just wont change gears or show me how fast im going
    в∞ѕтεכ √&
    Jul 2008
    NZ
    speed sensor must have gone no orange check engine light on the dash normally would throw a code with no vss pulses and will much up the gearchanges and have no speedo check the wires around the ecu you may have disturbed one where did you get the chip maybe it fried the ecu
    VR Executive S1
    Feb 2009
    cairns
    в∞ѕтεכ √&
    Jul 2008
    NZ
    VR Executive S1
    Feb 2009
    cairns
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the error light will only come on after driving too and it sees no pulses from the sensor hope it hasnt fried the ecu just funny it happened at the same time as you put the chip in
  15. #15
    VR Executive S1
    Feb 2009
    cairns
    в∞ѕтεכ √&
    Jul 2008
    NZ
    well it may not be the ecu.could be just coincedence that the sensor went at the same time or a wire has a loose connection or maybe dissconnect the ecu for 5 minutes and try it it should have limphome mode for when the sensor dies and should still change gears just not very nicely.
  17. #17
    VP Executive R-spec
    Jan 2005
    I only wonder why you bought anything from a guy that sells what he does might as well get some snake oil with the eprom and the hydrogen generator
  18. #18
    VR Executive S1
    Feb 2009
    cairns
    в∞ѕтεכ √&
    Jul 2008
    NZ
    whats your thoughts greenfoam apart from that posted above have you heard of an ecu dying as such as this
  20. #20
    VP Executive R-spec
    Jan 2005
    No, never heard of it. But did you solder the eprom in? and then solder the stock one back in? or how did you go about it? because alot of the time people dont get that right (the soldering) if the car is running the ecu should be fine, seems like the program on the memcal is not running and it's running in limp mode. Since thes stock one also doesn't work I'm suggesting its a bad solder (and a blown engine light bulb)
  21. #21
    в∞ѕтεכ √&
    Jul 2008
    NZ
    did you get a chip or a memcal maybe the chip isnt connecting properly if you have it in a socket
  22. #22
    VR Executive S1
    Feb 2009
    cairns
    VR Executive S1
    Feb 2009
    cairns
    ya know what when i turn the ingnition on theres a clicking noise where the fuses are
  24. #24
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    get your mate to check his soldering. 95% of the time, on soldered memcals, theres at least one pin not making contact properly, causing the problem.
    did he solder it around the right way?
  25. #25
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    clicking near the fuses, that would be a solenoid.
    Drop the cover under the steering wheel and have a feel/listen around, don't neglect the BCM either, itts that little black box tucked up above, that has a few solenoids in it too.
