Results 1 to 2 of 2
Thread: VR 3.8L SII Fuel Lines
    rSharwood Guest
    Exclamation VR 3.8L SII Fuel Lines
    Recently I have had a fuel leak from where the hose connnects directly to the fuel on the air intake side of the engine (ie right-side as you face the engine). Is this the return line or supply line??? It doesn't seem to be the hose connection. Is there an O ring near by where the fuel can be leaking from???? ie where the aluminium rail meets the hose connnector.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    I have had this problem as the rubber hose shrink or swell and the factory clamps won't clamp any harder so fuel dribbles past clamp.
    So I bought 6 new jubilee type hose clamps made for fuel injection and replaced all the fuel hose clamps under the bonnet.
    Have to bleed off the fuel pressure in the hoses first by pulling fuel pump relay and fuse out and running engine until it stalls and then replace clamps .
    Fuel will go everywhere if you try to undo hoses with full pressure.
    Here's a picture of the fuel lines with the brake booster removed showing the lines and the clamps I used
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  1. pulsing/thunking in the fuel lines
    By vnstu in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2007, 11:11 AM
  2. Fuel Filter Lines
    By vtdemon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-11-2006, 11:44 PM
  3. Noise thru fuel lines in VS V6
    By smaddock in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2006, 11:24 AM
  4. how do i take my fuel lines off
    By MON57A in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2006, 12:55 AM
  5. removing fuel lines
    By Holdenboy_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2006, 02:08 PM
