What differences are there between ecotec's from the different models ? Will heads , cranks, cams , valves, blocks , manifolds from one model fit all models ? And if so, are there any power gains to be had by fitting parts from a later model onto my VS ?thanks guys.
I believe the ECU/tune changed at least between the VT and VX, to lift the power from 147kw to 152kw
Not aware of any mechanical changes.
as danja posted
VS-VT is 147kw
VX-VY is 152kw
the difference in kw is from:
different EGR setup
manifold was refined
faster processing ECU
something else i just cant think of atm.
CAI is also different (obviously) but i doubt it performs any better.
touse the VT and up ECU you need the BCM as well yeah? or can you just get the vat tables deleted?
I know there was some hiccup with that idea.
