Results 1 to 11 of 11
Thread: Just got a level 3 cluster, question?
    HSV VT GTS
    Dec 2008
    Default Just got a level 3 cluster, question?
    hey guys just scored a level 3 cluster off a V6 calais with 19xxxx kms on it, my S pack has 186xxx so pretty close.
    i have pm'd markovr for some help with a modified loom and trip computer, but in the meantime can i plug it in and go without any trouble. i think all the guages will work (speedo, tacho, fuel and temp.) and the odometer i think??
    but is it going to beep and S*&% me off all the time until i can do the whole electrics?
    might be a trivial question but just wanna make sure cos although it only takes 5 mins to swap it over, not gonna do it if its just gonna beep its head off and not work.
    thanks
    Bite off more than you can chew, then chew like hell - Peter Brock
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    Quote Originally Posted by muggo05 View Post
    thanks
    it wont beep its head off but your cruise wont work and the lcd's wont work ither. other than that it will work as per normal
    HSV VT GTS
    Dec 2008
    dam i want cruise control!!!! so will the odometer lcd work or not?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The ODO wont work until the 4th plug is wired in.
    and 3 Dangerous non ABS VN's
    HSV VT GTS
    Dec 2008
    ok well i wont put it in until i get the loom from markovr. dont wanna be illegal or defective.
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    I just did this (a few days ago)
    See: Level 3 cluster in Executive (Not the usual)
    Anyway, I've included a description of each connector which might come in handy. also there's a link to tripin... in post 1, that has a few more diagrams.
    It should be all you need to get going :-)
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    I had the same problem. Had a cluster with about 5000ks more than on my car. I just waited the 5000ks to put it in. You can still put the loom in and get it tested and going. But if you dont wanna add k's to your car just plug the old dash in when your done and wait till the k's tick up.
    Reaper
    HSV VT GTS
    Dec 2008
    Quote Originally Posted by OzJD View Post
    yeah thanks mate i saw your thread but i'm not good with electrics so i'll need markovr's modified loom so i can pretty much plug and play!! my limits with electrics is installing a cd player in my car lol.
    @VRWAGZ - so once i get the loom from markovr i can install it with the trip computer and everything but keep using my level 2 dash and it will all work? until i reach the k's on the level 3 anyway!!
    VrWagz1's Avatar
    May 2008
    wollongong
    Correct, and if you got the speed alert still and if mark leaves you the speed alert plug in the loom he sends you, you can put that back in the hole for the moment too. The L2 cluster will work with the new loom. The main difference in the new loom is the 4th plug for the cluster, you just leave it unplugged when putting the L2 cluster in as it has no where to plug into it anyway.
    Reaper
    HSV VT GTS
    Dec 2008
    awesome, thanks buddy.
    OzJD's Avatar
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Wagz... it will work as Level 2 with trip computer?
    Current Issue(s)
    N/A
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. Dropping Level 3 Cluster into unready Level 2 ready VS
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2009, 03:56 PM
  3. not ur usual level 3 cluster upgrade question!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2008, 08:36 PM
  4. Level 2 cluster question
    By JD in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2008, 03:17 AM
  5. VS Level 1 to Level 3 Cluster Upgrade
    By Luv holdens guy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2006, 01:28 PM
