Results 1 to 2 of 2
Thread: Is this internal water leak common?
    vs commodore wagon
    Dec 2008
    Default Is this internal water leak common?
    Gday jcers.First of all for those who have followed my original posts on stalling then starting after an hour.Turned out to be the fuel pump.Im just about to do the saggy roof on the VS wagon.I have a leak on each side internally where the plastic mouldings connect at the top above the rear side long windows.It drips in exactly the same place on each side.Any tips on sealing the leaks up and where they would be? Thanks.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Can't help you with the leaks but re the headlining I can tell you that I ended up buying some fairly thin felt in a light blue colour from Spotlight which was about $40 for a sedan. You can buy the proper headlining material with the foam backing but it's a lot dearer. I was pretty happy with mine and the whole job cost less than $60 - I followed the "how to"
    more or less.
  1. leaking water in the front by passenger door, any common leaks there
    By controlled chaos in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2012, 02:37 PM
  2. Water Leak
    By hN! in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-11-2009, 10:47 PM
  3. Oh no,Water leak
    By jonny6guns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2008, 10:39 PM
  4. air leak?? common n help..
    By dave.b in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-01-2006, 08:36 PM
  5. VN water leak
    By NORTI in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-09-2004, 12:03 AM
