Results 1 to 15 of 15
Thread: central locking only does 3 doors
    VZ SV6
    Oct 2008
    Newcastle NSW
    Default central locking only does 3 doors
    Hi, what's the most likely cause for the right rear door to not be 'connected' to the central locking when presesd on the key or unlocking another door manually? If you pull up the door lock on the 'broken' door, all the other doors open so I assume its not ocmpletely screwed.... thanks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Dunno why but that door features prominently. Does it feel stiffer to pull up than the one on the other side? - if so then its probably gummed up - free with WD40. Otherwise I know the wires can break inside the door and to the pillar - check by using a multimeter across the actuator and see if there are volts (momentarily) when the doors are locked.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by alex2_s View Post
    Most likely issue will be bad contact on the connectors.
    It's door trim off to check.
    and 3 Dangerous non ABS VN's
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    it'll be something real simple, but no matter what its trim off. worst case scenario is the actuator is broken.
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    or the accuator motor is knacked my lh rear door is doing the same thing works on realy hot days
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Happened to mine a while ago. Take of the door trim and grease up all moving parts to do with the locking mechanism. This is what I did and it hasn't stuffed up yet and that was about 2 years ago. It wouldn't lock with the remote but if I locked it manually then locked the car with the remote it would stay locked and all others would lock. But when I went to unlock it they would all unlock no probs.
    LJay is offline Beware...Lady Driver :P
    VR Executive Series II
    Feb 2009
    I hve this problem too....only mine alternates :S
    Sometimes that back drivers side doesn't lock when I press the key button, or turn the key ( the key is playing silly buggers at the moment), so I open that door and manually press the button down....next time i get outta the car, the back drivers side locks fine but the back passengers doesn't lock...so have to manually press that button down too Its very frustrating...I've become accustomed to doing the walk around when I get out of the car now, to ensure all doors are locked.
    Would love to know what causes this....its driving me insane and I look like a dick walking around the car every time I get out :$
    HSV VT GTS
    Dec 2008
    mine has just started doing this today too, unlocks fine like the rest but doesnt lock. i can see it moving a bit when i press lock so it must just need freeing up. will take the door trim off tomorrow and have a look with some wd40.
    Bite off more than you can chew, then chew like hell - Peter Brock
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    as most of the above have said, trim off and check, wd40 if need or replace actuator or loom.
    i have the problem with the red tab, one side of the clip is broken and catches on the lock surround, quick push in and she works fine until it pops out again. check this if ur lazy before rippen the trim off
    whitevrboi is offline Just another white vr.
    VR Executive S2
    Feb 2008
    i had this problem too with my drivers side back door. The locking pin (aftermarket skull pins) just needed the slightest bit of pressure to the side or front and it wouldnt go down, as a quick fix i unplugged the central locking mechanism inside the door (had trims off already) and just keep it locked all the time :-D no one ever uses that door anyways and i dont need to remember to push the lock down everytime i get out.
    HSV VT GTS
    Dec 2008
    i fixed mine yesterday just by grabbing the lock and pushing it up and down about 20 times nice and hard. freed it up nicely and works every time now.
    Vk wags & Vl berlina
    Nov 2008
    this seems to be a problem thats comming up a lot lately as i've done five in the last few weeks the only way to fix this is to replace the locking motor in the door
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Quote Originally Posted by ephect View Post
    Yeah this is a problem I've experienced too awhile ago. Another trick is to put grease behind the plastic lock if this is not the problem, this worked for me on the other door evidently.
    HSV VT GTS
    Dec 2008
    my motor's ware working because i can see the plastic lock moving when i press the button. but mine is fixed now, just needed a bit of freeing up
  15. #15
    Bagged Vr berlina
    Mar 2009
    same with mine wd40 fixed it up
  1. Central locking - beware of doors that don't always open.
    By donccullen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-01-2012, 08:01 PM
  2. Put new central locking motors in but central locking still doesnt work???
    By richardbignutsonstato in forum Electrical Wiring / Questions
    Last Post: 15-02-2009, 03:41 PM
  3. central locking
    By kniever in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-09-2007, 11:52 AM
  4. vr-vs central locking key
    By MUNTED6 in forum Parts And Other Items For Sale
    Last Post: 16-09-2007, 04:49 PM
  5. Locking car with doors open
    By SPack in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-03-2006, 11:08 AM
