Results 1 to 10 of 10
Thread: is shaving ecotec heads worthwhile?
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Default is shaving ecotec heads worthwhile?
    Wanting to increase power without spending lots of cash .. how would a standard ecotec respond to shaved heads ? say 040 thou, or 1mm to give it some more compression. By my thinking this should give some more power without increasing fuel !!! Double bonus ... ?
    What do you reckon , are there any downsides to this in terms of idle or driveability, would the inlet manifold still fit ?
    VP Executive R-spec
    Jan 2005
    Nah I wouldn't do that, alot of VS's allready struggle with the compression they have now. You would need a cam with more duration if you were going to increase the compression anymore than it is
    greenacc's Avatar
    VE Berlina
    Jul 2008
    BUGGER !! Coming from the master himself i tend to believe.
    What probs would it cause ? pinging i guess.
    Back in the torana days this was one of the most common mods. Shame it doesn't aork any more.
    So what happens when people blow their head gasket and need to get it decked ? do they just shave it enough to get it flat , and that don't cause probs ?
    Reason for asking is i'm getting a little rocker / lifter noise in me ecotec thats done 240K. I'm thinking of doing a full head swap. and address those issues at the same time. So for ageing ecotecs is it usually the top end or bottom that lets them down first ?
    VP Executive R-spec
    Jan 2005
    Yeah they ping very easily, I don't think you would need much more compression to cause issues in alot of them (they aren't all the same but still). if your going to be pulling it apart that far however you may as well put a little cam in it? then you would get away with the compression. Spun bearing from old age is usually what break the V6's first
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    how much can you lower the compression with copper gaskets? for boost applications that is.
    Just thought i'd jump in while we are on the subject :P
    coasty's Avatar
    coasty is offline the voices told me to
    vz equipe & vt berlina both v6
    Feb 2008
    kanwal nsw
    ha ha ha . i remember putting 149 heads with big valves that near touch onto 186 to hot them up. twin or triple carbs, set of headers and a cam you were hot stuff. glad im not there any more.
    greenacc's Avatar
    VE Berlina
    Jul 2008
    Quote Originally Posted by greenfoam View Post
    ah OK, so you need more fuel in the chamber if the compression if higher.
    And just so i can be sure, which bearing do you mean spun bearing ? Is that a cam bearing, big end .... i can't imagine a big end spinning tho ?
    Thanks for the help. oh, and any suggestions on little cams while we're here ?
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Quote Originally Posted by cander24 View Post
    Its the main crank bearings that spin in the housing.
    holy hell that'd be nuts, im pretty sure foamy is referring to cam bearings/balance shaft bearings being spun.
    VS Berlina
    Feb 2007
    yeah cam bearings always spin in the 6's ive been told by allot of mechanics.
    Apparantly not doing frequent oil changes is the nail int he coffin for the cam bearings.
  1. heads for ECOTEC V6
    By Archers in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2008, 04:16 PM
  2. ecotec heads
    By vt_on_20s in forum Parts And Other Items For Sale
    Last Post: 21-04-2008, 09:40 PM
  3. FS - Ecotec heads
    By muvro in forum Parts And Other Items For Sale
    Last Post: 22-10-2007, 05:57 PM
  4. WTB urgent VT-VY ecotec heads
    By chevy_big_block_bro in forum Swap / Wanted to Buy / Trade
    Last Post: 15-06-2006, 06:32 PM
  5. vx ecotec heads on vr v6
    By race in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-06-2005, 09:48 PM
