Results 1 to 4 of 4
Thread: VS Caprice cruise control probs
    VZ Calais
    Aug 2005
    Mackay Qld
    Default VS Caprice cruise control probs
    G'day all,
    I took a little cruize 400ks down the coast. The cruise control was playing up on the way down.
    On the return trip, it refuses to work at all.
    The light on the dash is on. I cant turn it off. None of the other buttons on the stalk are working either.
    Any suggestions on where i should start looking?
    Cheers, Col.
    VS l67 statesman
    Dec 2008
    Which light? there are 2 is the the green one or the orange one ? One of my cruise control lights on the dash blew once ,it made it near impossible to use the the cruise control as I had no way of telling if it was on or off
    Also there is a swith under the exelerator check to see if its not loose and cancling it out,this happend in my VP
    VS Berlina 3.8
    Dec 2008
    Although this is most likely not causing your problem, make sure all of your brake lights are working properly. If there is a blown bulb, cruise control will not work.
    VZ Calais
    Aug 2005
    Mackay Qld
    The green 'ON' light is constantly lit.
    I cant switch it off.
    The brake/cancell switch is intact.
    I will check the bulbs tonight.
    Thanks, Col.
  1. Climate Control Vacuum Probs VY Calais
    By oztech007 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-09-2011, 06:52 PM
  2. VS Caprice Dash and VQ Caprice Climate control
    By CHEETR in forum Parts And Other Items For Sale
    Last Post: 16-03-2008, 04:42 PM
  3. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  4. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  5. vt acclaim Series 2 cruise control probs....
    By werdy666 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-08-2005, 07:47 PM
