Results 1 to 7 of 7
Thread: vs radio cuts out
    alan smithy is offline alan smithy
    vs wagon
    Aug 2008
    footscray melb.
    Default vs radio cuts out
    can anyone follow this?. radio works fine ,all pre sets ok till i turn ignition off, then i have to manually switch it back on. all memory is erased.cd side works fine. i see 2 radio fuses and both ok. it,s getting frustrating having to turn on , find the frequency,then station ect. must be another fuse somewhere. any help appreciated.
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    It means that you arn't getting a constant 12v to the radio (probly the wire broke) But that one wire keeps the power going to the radio with the engine off and stores all the memory and what not
    System's Avatar
    System is offline Control is a way of life
    2005 VZ commodore exec
    Oct 2007
    yeah, i'd pull the radio out, and recheck the connections, did you soulder/twitch them up yourself?
    Unions: the people who brought you weekends
    vs wagon
    Aug 2008
    footscray melb.
    thanks all. i forgot to say it,s not origanal radio someone has put a pioneer with detachable face. i was thinking maybe there is a fuse in there.but maybe i should take it out. the only trouble with that isradios don,t seem to go back as they should when i take them out.
    VS 3.8l Exec
    May 2006
    Ya mums house!!!
    yeah the constant 12v is not connected...
    find this and connect it.. problem solved
    vs wagon
    Aug 2008
    footscray melb.
    ok i guess i look for 2 wires that looked like they were joined and have come apart.
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Yeh, generally its a yellow wire from the head unit (not always though).
    Check your fuses as well, depending on how it was wired in, it may be a blown fuse under the dash
    Generally:
    Red: Accessories 12v+
    Yellow: Constant 12v+
    Black: Earth
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
  1. vr cuts out
    By aussie_cruzin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2009, 04:35 PM
  2. Help air con cuts out
    By Butterflygurl_777 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2009, 12:58 PM
  3. vs radio cuts out
    By alan smithy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2008, 07:00 PM
  4. Power steer cuts out then cuts back in!!!!
    By fnlow1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-05-2008, 01:03 PM
  5. Fan cuts out VC
    By Outlaw Torn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-11-2005, 08:03 AM
