Results 1 to 3 of 3
Thread: Rear Power Windows
    Rumbl's Avatar
    Rumbl is offline = ShAkE AnD bAkE =
    VR V6 berlina-VS ss
    Jan 2005
    campbelltown nsw
    Default Rear Power Windows
    Hey
    both my rear power window's wont go down ive checked the switch with a test light it work's fine then i tested the wire's inside the door that comes off the motor the test light came on.
    What would this problem be? any help will do
    thanks
    GMH95's Avatar
    GMH95 is offline Sorry I dont do Resprays
    VS Berlina S1 3.8l
    Jan 2009
    Western Suburbs
    mayb the motor or the regulator if the swtiches are ok my regulator is almost dead try finding one second hand cost too much for a brand new one
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Try running 12v power directly to the window motor to see if it moves - disconnect the factory wiring to the motor first. If it moves or tries to move then it may just need lubricating - window guides etc. The back ones usually go first as they are not used often and tend to gum up.
  1. Options..power seats... power windows??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 06:01 PM
  2. VT Berlina rear power windows
    By samuels in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-01-2008, 08:11 AM
  3. VT Berlina rear power windows
    By samuels in forum Electrical Wiring / Questions
    Last Post: 17-01-2008, 06:45 AM
  4. rear power windows making scratching noise?
    By axemurderer101 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-12-2007, 09:01 PM
  5. [VP Calais] Rear power windows not working
    By sakid in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-10-2007, 08:21 PM
