hey i was wonder if anyone knows how to fit these window back in been trying for the last hour or 2 i add a pic so everyone knows which window im talking about
Check this post...it should fit the bill:
Rear quater window
wrong window its the one in the middle of the rear window and the quater one where people break into your car that window
yea mate i just replaced mine on the weekend, b!tch of a job. From memory you need to get the rear window sitting in the rail of the bit that runs to the top of the door and slide it as far to the front of the car as possible. then get your window u wanna fit to match up with the rail that holds the glass and slide it all the way down so that it is sitting in the proper place at the bottom of the window then a bit of brut force to get it to sit snug. I used a screw driver to "help" the window slide in by pushing the glass towards the inside of the car. Its tricky but if you take ur time u can get it. Hope this helps
