Results 1 to 3 of 3
Thread: Whats my compression ratio?
    VR Executive S 3.8
    Oct 2007
    Default Whats my compression ratio?
    Did a compression test yesterday with these results. (on a VR V6 with LPG, 260,000KMs on the clock)
    1 = 1100kpa (1190kpa after adding oil to cylinder)
    2 = 1220kpa
    3 = 1200kpa
    4 = 1240kpa
    5 = 1250kpa
    6 = 1240kpa
    From the looks of cyl 1's plug, it looks like its running a little lean, but its not too bad.
    Now how do I work out my compression ratio, and how healthy is my engine? Thanks guys...
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    compression ratio is measured diffrently this is just a compression test to tell how the motor is doing on each cylender.
    all looks good to me cyl 1 is down a little, may have a burnt valve but is nothing to worry about at the moment...
    VR Executive S 3.8
    Oct 2007
    But can't you work out the compression ratio from this? And I am about to change inlet manifold gasket but I imagine this wouldn't affect my readings?
  1. compression ratio of my efi 355
    By eaton v8 in forum V8 Development and Modification
    Last Post: 19-10-2008, 08:10 PM
  2. Compression ratio
    By geardys in forum V8 Development and Modification
    Last Post: 04-11-2007, 07:11 PM
  3. compression ratio
    By vkhawkey in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-04-2007, 11:10 AM
  4. Compression ratio for VN on straight gas.
    By colmiller in forum V6 Development And Modification
    Last Post: 25-10-2006, 11:58 AM
  5. Compression Ratio + Rebuild Kits
    By dezrik in forum V8 Development and Modification
    Last Post: 05-07-2006, 06:27 PM
