Results 1 to 7 of 7
Thread: Front Oil Seal
    VS Executive
    Mar 2009
    Default Front Oil Seal
    Leaking a lot of oil and after taking it to the local mechanic who couldn't identify where the leak was coming from suggested I clean it with a Gurnie and come back. Leak is getting worse and looks to me like it's coming from the front Oil Seal. I'm just curious how big a job it is to replace it and what should I pay if taking it to a mechanic,
    regards David
    vs wagon
    Jan 2009
    darwin
    it should be a max of two hours. before you take it to a mechanic open bonnet ,run engine & check harmonic balancer is running straight. if its buggered you could be up for extra for a new one
    vg ute v6 5 speed
    Jun 2008
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check the "how-to" section as I think there is one there for changing the CAS....the seal is easily changed once the HB is off. May pay to change the CAS whilst you are there just for luck.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    yeah it is easy enough to do, the seal costs about 15-20 bucks. They seem to last longer if you wipe grease on the seal lips before fitting also.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Quote Originally Posted by greenacc View Post
    You lost me on the last sentence
    greenacc's Avatar
    VE Berlina
    Jul 2008
    Well, i fitted one from repco the first time i changed my CAS and about 6 weeks later the seal had shat itself. I replaced it again and someone suggested filling the lips with bearing grease to keep it lubed until the oil gets to it. Whatever the reason it worked well and the seal is still in tact 12 months later ... and the grease was still there last time i checked.
  1. front timing case seal
    By Galixia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-12-2008, 10:22 AM
  2. Should I replace the front crank seal?
    By Wagon_Wheel in forum General
    Last Post: 21-12-2008, 01:16 PM
  3. Front windscreen leaks water at the top seal
    By frustrated in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-03-2006, 08:21 PM
  4. Front Window Rubber Seal
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2005, 02:42 PM
  5. Replace Front Crnk Seal
    By mikey5290 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2004, 04:03 PM
