Results 1 to 5 of 5
Thread: Installing lsd, what else do i need?
    VY SS
    Jun 2006
    Albany
    Default Installing lsd, what else do i need?
    so i got my lsd in the post today so i will be putting it in this weekend, just need to know what things i will need when installing it. The things i know i need are new oil for lsd, diff cover gasket, grease for axles and maybe new bearings for the axles while they are out. Just need to know if i have missed anything
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    You've pretty well covered most things to expect. Do a close inspection of your axle bearings and diff centre carrier bearings while they're out look for any pitting or any spots that have worn through the case hardening. Far better to relace them now if needed as they are only like $20 each.
    VY SS
    Jun 2006
    Albany
    yeah the lsd has new bearings and everything so just gotta check everything else, do the bearings on the lsd need to be greased or is the oil in the diff enough to keep it lubed lol
    vs executive s1/ vz berlina
    Mar 2008
    a limslip additive is must for lsd, pair of new bearing for lsd carrier and make sure check the backlash between pinion gear and crown 1st before you take out the old carrier so u have the idea on the clearance when u put ur new lsd carrier. and careful not to mix the carrier spacer...
    Aug 2008
    NSW South Coast
    Quote Originally Posted by axemurderer101 View Post
    No you dont need to grease them. Just give them a good coating of oil when you in stall them and once they're installed they run in an oil bath for lubrication.
  1. Installing ABS
    By dbarnes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 12:57 PM
  2. installing a UHF set in VY
    By junesshadow in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-02-2006, 10:16 PM
  3. installing mi hu
    By jamiekratin in forum Car Audio
    Last Post: 06-01-2006, 04:28 AM
  4. Amp installing
    By BITE ME! in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2005, 06:47 PM
  5. installing a CAI
    By fu2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-11-2004, 08:26 PM
