Page 1 of 2 12 LastLast
Results 1 to 25 of 38
Thread: Odd vibration around 80km/h
    Jun 2005
    Default Odd vibration around 80km/h
    Posted this up before, but still havent worked out the problem. Driving my car between 60-90km/h i notice a very annoying pulsing vibration. It seems to happen every second. Probably 0.8 seconds to be close to exact, and seems to increase a little in frequency/harshness as the speed gets higher. Once i hit 100km/h, its not as noticable. It is very annoying though. Every time it vibrates it shakes every loose thing in the car and gets very irritating. Could it be wheel weights, tailshaft unbalanced, or something else?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VP Executive R-spec
    Jan 2005
    Jun 2005
    was his a similar issue to this?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    im thinking torque converter.. try this, when the vibration is pressent, drop the gearstick from D to 3rd without changing the throttle position and see if the vibration disappears
    other than that if its still pressent, could be centre bearing, possibly wheelweights or tailshaft
    VP Executive R-spec
    Jan 2005
    Yeah he had weird vibrations, I think he had a broken engine mount, maybe the gearbox mount too
    Jun 2005
    i should also mention its manual
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by ephect View Post
    It's a manual
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    lol sorry guys, stocky i should have known better! im guessing it does it in all gears..
    Foams i think ur right bout the mounts, either engine or gearbox
    Jun 2005
    well the engine mounts were replaced about 6 months ago just after i bought the car, so possibly the gearbox mount? anyway for me to go out and check it?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i'll check my manual tonight if noone posts up info before hand.
    vc starfire
    Mar 2009
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    ok, below is the proceedure for check and renewal as per Haynes
    1. Raise the vehicle and place it securely on jackstands
    2. place a lever or large screwdriver between the crossmember and the transmission and try to prise the transmission up and down. if the mount is cracked or torn, renew it.
    3. unbolt the mount from the crossmember and from the transmission.
    4. support the transmision with a floor jack and raise the transmission until the mount stud is clear of the crossmember, then remove the mount.
    5. refitting is the reverse of removal.
    will check the front for any more details on vibrations
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    VR Executive S1
    Mar 2009
    Sounds like you need a wheel balance explains why you can only feel the vibration at certain speeds, same thing happened with my car at 90Km.
  15. #15
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
  16. #16
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Q: is the vibration relative to the rpm or speed?
    if its rpm orientated regardless of gear, always round say 2000rpm, its not drivetrain related
    if its speed orientated, its drivetrain related
  17. #17
    Jun 2005
    i dont think its gear related. seemed to be the same if i was in 4th or 5th at 80km/h, and i think with the clutch in too.
  18. #18
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i would be getting wheels balanced first, start simple.
    other possible causes
    bent or dented drive shaft
    worn uni joint bearings
    loose drive shaft mounting nuts/bolts
    or worn transmission rear bush
  19. #19
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
  20. #20
    Jun 2005
    nah its not a buckled wheel. theyre all fine
  21. #21
    dijm8's Avatar
    dijm8 is offline What You Looking At
    VZ SS LS3
    Jun 2006
  22. #22
    Jun 2005
    had a look at the transmission mount. it seems fine. thinking i might swap wheels over with the VN to test it for a balancing issue. what tailshaft rubbers do i check?
  23. #23
    VP Executive R-spec
    Jan 2005
    Seems fine? or is fine ? there's a big difference, you can't tell unless you've pulled it out and wriggled it
  24. #24
    Jun 2005
    i tried the screwdriver method above. didnt seem to want to move the box much at all
  25. #25
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Check your centre bearing on the tail shaft.
    Is it a grumbling sound coming from just behind you about level with the back of the console?
    If it wasn't for the vibration I would have said front wheel bearings, but because it vibrates as well it sounds like a tail shaft issue.
    Visit my Facebook page
  1. Engine revs changing up/down when coasting over 80km/h
    By vsuterus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 09:18 PM
  2. Vibration
    By lilzen96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2008, 02:19 PM
  3. Staffy + VY @ 80KM/PH = FRONT END GONE. VZ REPLACEMENT
    By nEb. in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-06-2008, 02:04 PM
  4. Nosie from Engine ot Gearbox while travelling 80km+
    By bsbozzy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-09-2006, 02:20 PM
  5. vibration
    By remmie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-08-2005, 06:29 PM
