Results 1 to 8 of 8
Thread: Front wheel sealed bearings question
    VS
    Aug 2007
    Default ........................Front wheel sealed bearings question.........................
    I went down to a motor spare parts place and wanted to buy 2 front wheel bearings.
    Was told the price is $285 per side as the VS has sealed bearing.
    Ended up at the wreckers and got a pair for $200 including rotors..
    Some one told me that these come in a left and right hand sets and should be marked.
    I had a good look over them and could not find any printed markings showing anything different..
    Or will only a left fit on the left hand side due to bolt on pattern.
    Any info..??
    Azp
    Azp is offline
    VN/VR
    Feb 2009
    I'm fairly sure that if you have ABS if you place it on the wheel studs on the ground and face the two close bolts towards you with the third bolt facing up, then the abs sensor plug is on the left for the LHS hub and on the right for the RHS hub.
    VS
    Aug 2007
    Azp
    Azp is offline
    VN/VR
    Feb 2009
    There's probably no difference between left and right then but not 100% sure on that.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Vehicles without ABS have the same part number for LH & RH hubs. Vehicles with ABS (whether 5 link or IRS) have different part numbers for LH and RH hubs. Since you don't have ABS, you need to make sure that your hubs came from a vehicle without ABS.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If the hubs were designed for ABS they will have an electrical connector fitted.....no connector = no ABS.
    VS
    Aug 2007
    The VS I got has stock standard sealed bearings and that’s what I purchased..the same type.
    Only wanted to know if there is a left or right being sold .
    Or was the information supplied is only for ABS type cars
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    If you don't have ABS and you got them off a car that didn't have ABS then there is no difference left or right. Just sit them side by side and if they both look identical then your sweet.
  1. VT II Front Wheel bearings/Hubs
    By YByN8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-11-2008, 11:00 AM
  2. Replacing front wheel bearings- NON ABS
    By vnv8driver in forum Holden Commodore How-To's
    Last Post: 18-06-2008, 11:40 AM
  3. front wheel hubs/bearings
    By Burnout_bro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-09-2007, 11:05 PM
  4. Front Wheel Bearings
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2007, 11:02 PM
  5. Front wheel bearings
    By vinnywelsh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-05-2005, 01:39 PM
