Results 1 to 18 of 18
Thread: VR And VS Automatic trans the same?
    VS Commodore
    Feb 2009
    Default VR And VS Automatic trans the same?
    I found one or two threads regarding this but didnt give me a 100% Answer..
    My friend has a VR stato that has done the trans.. we got a couple of VS auto trans here but will it work with the VR Computer? i understand they will bolt up.
    Any help appricated and if they dont work is there any work around to easily make it work? Thanks.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i assume they are both V6's? yes they are the same box, they are both 4L60-E
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    Most vs boxes should have 6hdd printed on them, if the one from the VR has 4hdd on it and the one from the VS has 6hdd on it, I am fairly sure you should swap the extension housings over so the speed sender works properly.
    Thats just what ive read onhere anyway, otherwise they are both electronically controlled and both bolt straight up.
    vs executive s1/ vz berlina
    Mar 2008
    u can put vs tranny into vr and no problem with the ecu but not vr to vs, just use the extension housing of vr .
    VS Berlina 3.8
    Dec 2008
    I've got a 4HDD in my VS, it's the factory box.
    I have read that the number corresponds to the year it was made (e.g. 4HDD would be made in 1994). I'm not sure about this though.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Quote Originally Posted by _R_J_K_ View Post
    correct, the * in '*HDD' denotes the year it was manufactured
    94 4HDD
    97 7HDD
    VS l67 statesman
    Dec 2008
    some VS's had the Vt autos in them not sure of the differences though,this was mainly in some Late series 2 and series 3 statesmans
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I think you'll find that the ECU operates the VS box whilst a separate PCM operates the VR box. What this means is that the electrics plug from a VR will not fit the VS box...from memory it has and extra pin on the connector. The extra pin has something to do with locking the torque converter. It's possible to modify the wiring and this problem has been covered before so maybe a search will find a proper explanation.
    VS Commodore
    Feb 2009
    ok i got my hopes up til i read hako's response.. ill see what i can find. Thanks everyone.
    VR Commodore Exec
    Oct 2007
    Ballarat
    I was told when i needed a new auto for my VR (it has a 4HDD) that 5HDD's fit but you need to modify something and 6HDD's don't fit in the VR. Thats just what i was told so i just got another 4HDD.
    89 VN Exec, 94 VR SS
    Dec 2007
    I thought since the VR had a buick it had the same trans as a VN/P. So Holden had a different trans for one model then changed it when the VS came along?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    no VR and VS boxes are the same both 4L60E..
    refer to: I think my gearbox is dying, so..
    VR Commodore Exec
    Oct 2007
    Ballarat
    Quote Originally Posted by 89 vn View Post
    I'm pretty sure that the VN/VP trans is cable shift and the VR/VS trans is electronic shift.
    VS 3.8l Exec
    May 2006
    Ya mums house!!!
    VR - VS trans are very similar, they have been built the same, but for a VS i would highly recommend a later model trans as this reduces issues for the future!
  15. #15
    VS Commodore
    Feb 2009
    Alright well being the same model regardless of having different pins it should be able to be rigged up one way or another? It seems being a VR Statsman it has the extra pin anyway? All good ill start swapping.
  16. #16
    VS Berlina
    Feb 2007
    the VT box has alluminium pistons, while the earlier ones used plastic I think, but dont quote me on it, along with a few other minor things like that, all parts between a VT box and a VS box are interchangable as far as I know.
    to the OP VR and VS boxes both are run via the ECU.
    go to you tube and look for "boxwrench 4l60e" thats a good place to start if you are interested in learning about the internals of your auto, from there google is your best friend.
  17. #17
    Vk wags & Vl berlina
    Nov 2008
    just change the extension housings over so the speed sender works properly.
    i've done this swap once before and had no probs so far
  18. #18
    VS Commodore
    Feb 2009
    Good point Amped. and yeh will give it a look thanks DannyBoy.
  1. Automatic Trans needs replacing
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2008, 04:46 PM
  2. FS (SA): EFI Black Motor and automatic trans
    By bezz in forum Parts And Other Items For Sale
    Last Post: 18-01-2008, 03:04 PM
  3. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  4. Automatic trans leak help
    By vsv8berlinawag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2007, 09:33 PM
  5. Installing Automatic Trans
    By Toyoden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-03-2006, 12:51 AM
