Results 1 to 8 of 8
Thread: IRS CV boots
    Azp
    Azp is offline
    VN/VR
    Feb 2009
    Default IRS CV boots
    Hey guys,
    One of my outer diff CV boots needs changing but I'm a bit unsure how to go about it. Anyone know an easy way?
    Disturbed_vegeta's Avatar
    Disturbed_vegeta is offline I'd Prefer To ROAR!
    Vs Statesman, Vr Senator 185I
    Dec 2005
    Burpengary
    i have the same problem but with the inner ones. i was just planning on replacing the whole thing tho.
    Azp
    Azp is offline
    VN/VR
    Feb 2009
    Is it just a matter of undoing the 8mm(?) hex bolts, cutting the old boot away and removing a C clip and sliding the CV joint off the drive shaft?
    Azp
    Azp is offline
    VN/VR
    Feb 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by Azp View Post
    That's basically what the Gregorys manual says....so in my books that would be the course I'd take. Pretty hard to damage anything as long as you take your time.
    VP Executive R-spec
    Jan 2005
    I just take the entire shaft out (all the allen bolts) then undo the clips repack the bearings with the new boot on and put it back in the car. It's very easy
    Azp
    Azp is offline
    VN/VR
    Feb 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Thanks guys. Those allen bolts are a pain. :S
    I'm told they are a breeze with a 400mm length of waterpipe.
  1. Changing boots
    By FamiliarOfZero in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-01-2009, 02:43 PM
  2. vn-vs boots?
    By CAM05L in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-02-2007, 07:06 PM
  3. Custom boots VH
    By scolari in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-07-2006, 12:14 AM
  4. Boots!! (Tie rod)
    By Fully in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2005, 10:27 PM
  5. New Boots
    By ClairBear in forum Jokes/Humour
    Last Post: 28-03-2004, 02:25 PM
