i did the code check and i got code 65, as far as i know code 65 means oxygen sensor rich.. ?
i dont understand what this means, can anybody help me?
It means the left hand oxygen sensor is getting a rich signal....in other words the sensor is indicating that the left hand bank of cylinders are pumping out exhaust gases that contain too much unburnt fuel. In theory the oxygen sensor detect the rich mixture and tells the ECU to reduce the amount of fuel the injectors inject so that a rich condition does not exist....or something along those lines.
First thing you should do is clear that code by removing the engine fuse for 10 seconds, drive the car for a day or two and retest. Hopefully the code will not reappear but if it does you'll then need to figure out why....Hope this helps.
okay mate thanks, i will give that a shot and see how it goes, fingers crossed.
came up with 12, all is good![]()
