Results 1 to 12 of 12
Thread: is my car IRS or non IRS please help
    blaze's Avatar
    blaze is offline ridin dirty
    SILVER BULLET
    Jul 2006
    bunbury
    Default is my car IRS or non IRS please help
    hey i need to know wether my car is irs or non irs ( independent rear suspension) its a 1995 model 5.0L VS executive, i use to know but know i forgot, u use to look at the diff for something. plz help as i just bought new Damn low springs of ebay and need to tell the seller!
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    dude, if your gonna ask that question you gotta post a pic of your diff at least, or check out one of the other posts that have asked the same question and compare.
    Are there any stickers on the dash that say ABS/IRS , or Radial tuned suspension or anyting ?
    blaze's Avatar
    SILVER BULLET
    Jul 2006
    bunbury
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    its a exec. its not irs dude.
    look under it... if it has a diff or if it has a box with two indiviual arms coming out of it on a angle.
    but exec + radial tuned suspension = normal diff non irs
    SIR LS1
    the two ton go kart
    blaze's Avatar
    SILVER BULLET
    Jul 2006
    bunbury
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    irs shorter and will look narrower on each end. normal springs are usually longer and same dimension all the way. whats the ebay link
    SIR LS1
    the two ton go kart
    blaze's Avatar
    SILVER BULLET
    Jul 2006
    bunbury
    StockoVRWagz's Avatar
    StockoVRWagz is offline Formerly White50L
    '94 VR Wagon
    Feb 2008
    Northern Suburbs, SA
    3.9??
    sure its not 3.08?
    and unless its a BT1 I bet it would be non-irs as above.
    (I have VR 5.0L exec BT1 and it has LSD, IRS)
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    regardless of the ratio, its either IRS or live. the ratio are for the gears inside the housing.
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    vs exec's are live axel im pretty sure
    Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
    My VS CLUBBY!
    237.2RWKW - 318.1HP - 926.4 NM
    Quote Originally Posted by ari666 View Post
    "putting additives in your oil is like putting things up your bum.... to some people its the best thing in the world, but to me its the most horrid thing i coud possibly imagine"
    blaze's Avatar
    SILVER BULLET
    Jul 2006
    bunbury
    i could barely get under my car so these are the best pics i could get without getting the old un faithfull holden jack out. yeah its a 3.9 lsd heres the link u asked for there custom springs lowers ur car 3.5 inches or even lower
    Custom Ultra Low Springs most cars Commodore R34 Pulsar - eBay Coil Springs, Suspension, Steering, Car Parts, Accessories, Cars, Bikes, Boats. (end time 10-Mar-09 02:45:29 AEDST)
    blaze's Avatar
    SILVER BULLET
    Jul 2006
    bunbury
    grrr pics didnt work try againn ....
