Results 1 to 11 of 11
Thread: Air problem at idle
    VX S2 S-Pac
    Oct 2005
    Default Air problem at idle
    I have a VS with CAI and a 2.5 cat back lukey, problem is when its first started for the first 5mins theres a problem at low revs.
    Iv only noticed it at idle so far as its not yet licensed to drive around but if i stab the accelerator the car almost dies (stops firing a couple cylinders it seems) for a few seconds then revs up as normal
    When iv sat at the engine bay and tugged on the accel cable theres a sorta sucking air sound around the top of the air chamber, but that could be the sound of the CAI travelling.
    My bros VS ute had the same problem which was fixed slightly when he replaced his 2.5" exhaust back to standard 2 1/4".
    Is this nothing to worry about (exhausts fault) or is it most likely something else, i unplugged the air sensor at the throttle body (not the throttle sensor but the other one around there) and it made the problem a lot worse but it was the same sorta problem.
    Its not a huge problem as it goes away itself and its only if u really stab the accelerator just after starting, but yeh it doesnt sound the best at the engine end, as for the exaust end it actually sounds good as it makes a deep rumble and gurgle.
    VR through to VX wrecking in WA, must get rid of these!
    http://forums.justcommodores.com.au/...res-vr-vx.html
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    you could have a vacuum leak somewhere, u'd have to narrow down where the sound is coming from.
    it may just be the normal sound the CAI creates, but you mentioned
    if sounds like its not doin anything for about .5 of a second, thats totally normal
    if it runs rough for a couple of secs then revs fine, u'll most likely have sparkplug/lead problem, thats at a quick guess.
    Check your error codes (how-to section) that may give us more info on what could be the cause
    HSV VT GTS
    Dec 2008
    sounds like the same problem a lot of us are having. check out the thread VS rough on start up, then fine
    we havent fixed it yet either but same problem
    Bite off more than you can chew, then chew like hell - Peter Brock
    1LOWVX is offline How Low Can You Go
    VE Omega
    Feb 2009
    have u re mapped ur computer for CAI, which can be done by removing your engine module then putting it back in and starting the car and holding it at 2000 rpm for 5 mins your computer will re calibrate for the CAI. As that is what i had to do when i put my pod filter on my VX to get air / fuel ratio correct again
    Good Luck
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    the ecu is self learning, there really isnt much u u need to do.. occasionally u need to reset the ecu, to which you either remove the engine fuse, or remove the + lead off the battery generally 5 mins, sometimes it takes longer to clear the ecu.
    VE Omega
    Feb 2009
    thats what i ment theres no diffrence between removing the battery lead or engine module u get the same result my mates that have had VR-VS before they updated found a better outcome from removing engine module
    HSV VT GTS
    Dec 2008
    mine had this problem before i installed my CAI and still does it after.
    VE Omega
    Feb 2009
    have u checked your injection system, it sounds like there could be a probably there and if all else fails take it to holden and get them to run dignostic check on it
    VS 97 Commodore Ute
    Mar 2009
    Quote Originally Posted by tyrefryer View Post
    i had a problem sounded something similar (97 vs ute)
    when i stabbed the accelerator the engine shook around sounded like it wanted to stall...one of the coil packs died...
    i didnt have that air noise problem tho.
    VX S2 S-Pac
    Oct 2005
    Yeh the only problem is it fixes when its warm and iv had a faulty coil pack b4, that didnt fix ever. and also the air sound could well just be the CAI sucking.
    But wouldnt the injections always have a problem not just when cold?
    I might try resetting the ECU cos the CAI scoop has been off the car for a while but still i cant imagine its gona help the cold start problem.
    Anyway its not a huge problem just a bit bugging but it doesnt take long to go away and then i can stab the accelatator as hard as i want at idle ant it will respond instantly
    VE Omega
    Feb 2009
    when i had my injector problem it was only on start up from to much fuel leeking thru the o rings
  1. LPG Problem, Won't Idle
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-06-2008, 05:57 PM
  2. Vn Idle Problem
    By Doolang in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-08-2005, 12:14 AM
  3. Idle problem
    By DISTURBED in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2005, 09:26 PM
  4. Vn Idle Problem
    By keatz_RedVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2004, 06:25 PM
  5. Vn V6 Idle Problem
    By jackus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2003, 07:12 AM
