Results 1 to 9 of 9
Thread: shock absorbers for VR with IRS
    VR Acclaim
    Feb 2009
    Default shock absorbers for VR with IRS
    I was looking under the car today while the auto was being serviced and noticed the rear shockies (and probably the front) look like the originals.
    Anyone know whats a good shockie at a fair price,I dont need anything fancy?
    Its just a work hack,not lowered or anything,.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    monroe are a decent cheap shock, another option is a set from holden. always compare prices thou
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If they're not leaking and the car doesn't show any signs of them not doing their job then there will be little to gain...maybe a thinning of the wallet as you'll have little change out of $400. My opinion only.
    VY SS
    Jun 2006
    Albany
    go kyb's my fronts cost $220 and rears cost $120 so $340 all up but my car is live axle and i installed them myself
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    yeah for the price KYB. Monroe if you want to support the Aussie economy.
    The rears are piece of cake to DIY. GSL sells KYB pretty cheap.
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by greenacc View Post
    Definitely. Monroe are way overpriced for their performance and quality. Their entry level stuff, which is about KYB price, isn't anywhere near as good. The GT Sport is getting up there, but by that stage so does the price.
    Monroe is just a rebranding of America Giant Tenneco:
    Tenneco Corporate Web Site - OE and Aftermarket Automotive Parts
    Ok, so buying KYB's is supporting the Japs, but then as with Monroe it also goes through 3 companies in Australia before getting to the customer, so much of a muchness really...
    A full set of KYB shocks to suit VR with IRS normal height would be $374
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    VR Acclaim
    Feb 2009
    Thanks for the replies. I got quoted $795 from one suspension shop to supply and fit Monroe Gas shockies and do a wheel alignment.
    Ill keep looking for a while.
    The old ones dont ride to bad but going through some S bends on the freeway entrance made the car sway to the point where I thought the ass end was going to overtake the front.
    greenacc's Avatar
    VE Berlina
    Jul 2008
    Diesel Dude, my advice is go and buy some heavy duty shocks for the rear only, and fit them yourself. There is only 1 bolt on the bottom and one nut on the top so its a 5 minute job for a 5 year old, and that way labour is free. Then see how the car rides after that and go from there. I found this stiffened up the back end nicely on mine. I used pedders sports rider shocks in the back for this reason, no doubt other brands would do same job. just my 2cents
    Bagged Vr berlina
    Mar 2009
    i got some shorten gabierls in the rear of mine for 60buck a set from supercheap
  1. Shock absorbers how to
    By hoju82 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-03-2008, 07:28 PM
  2. shock absorbers which ones ?????
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2008, 10:48 AM
  3. Shock Absorbers
    By wes_v8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-08-2006, 10:09 AM
  4. Shock Absorbers
    Last Post: 04-02-2006, 03:47 PM
  5. Shock Absorbers
    By MidZ in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-08-2005, 12:18 AM
