My VR gets a mild vibration through the steering wheel at 100kph.
Ive just had new Michelin Energy 205x65x15 fitted. I presume they were balanced(I may have to have it rechecked).
The vibration was there before the tyres went on.
Any ideas what else can cause vibration? Steering feels tight,no slop or clunks.
I do need new shocks but I dont think that would affect it
My VR is the same. I also would like to know what causes it. I have 235/45/17's on mine. Tyres were balanced and aligned and still the same. I am looking at my suspension next but what on the suspension could cause this?
A slight amount of play in the tierod ends or the rackends can cause this problem. You can test by raising each front wheel and place a hand on the wheel at 3 o'clock and the other hand at 9 o'clock and try and move the wheel sideways - there should be no play.
my vr also vibrates steering wheel @ 100 kph i got told it is a pair of bushes at the front of the car you can see them without jacking car up just look under front bumper near the front tyres at the front end of car i am yet to get mine fixed tho let me know if this helps![]()
Same problem with my VR ute. I reckon hako is on the money because i had my shocks and struts replaced only about 6 months ago and the problem still occurs. I will try what he suggested and post the results!
Holdens go fast...very fast.
FORD:
First
On
Rubbish
Dump
:P
S> CLEAR REAR BRAKE/TAIL LIGHT UNITS ( Got both left and right, from a VR ute),GOOD CONDITION, $70PICK UP ONLY 2197 N.S.W. PM ME
z bar bushes need replacing
Good answers ,will check them all. Thanks
