Results 1 to 19 of 19
Thread: my vs won't start :bang:
    VS-1995 Hydrogen Fuel Saver
    Dec 2008
    Braidwood
    Default my vs won't start
    hey mates..
    I don't know what's happening with my vs today, as I turn the key, there is nothing happening, the electrical seems okay as the dash lights goes on but when the key is turned fully there is nothing happening at all, no sound. No start.
    I noticed it has been going funny since is bought it. Sometimes you would turn the key and there would be a few seconds delay before the battery would kick in.
    Is that any common problem on vs?
    Cheers.
    Ps: The gear handle is on P.
    Saving above 40% of fuel with my Hydrogen on board generator.
    VS 3.8l Exec
    May 2006
    Ya mums house!!!
    hmm certainly is a tricky issue your having, I would probably start by checking error codes, see the how to section for this information...
    next to that there maybe no charge in your battery, your earth cable maybe loose, your ignition barrel maybe stuffed, there maybe a short somewhere..
    it's really to vast of an issue to indicate what it is at this stage...
    So as above check error codes, and those couple things mentioned and get back to us
    Good luck mate
    Dec 2008
    Braidwood
    how do you check error codes.. is there a way to reset the ecu?
    VS 3.8l Exec
    May 2006
    Ya mums house!!!
    before restting ECU you need to check the error codes in your car...
    Checking error codes VR/VS (Revised)
    go here, this gives you a detailed explaination of checking for errors....
    Dec 2008
    Braidwood
    okay. trying that.
    '97 VS Commodore + '98 E36
    Apr 2005
    hmmmm...try this
    every time you start your car start in neutral and tell us if it starts straight away.
    if it DOES start all the time, then you have a problem with the inhibitor switch in the auto selector
    Dec 2008
    Braidwood
    I have tried to start it in N.. same deal
    I'm trying now to reset the computer. To my sense it must be an electronical problem, regarding the battery seems ok, I have 12v and I got a reading of 13A with a load on it.
    Dec 2008
    Braidwood
    I've unplugged the battery, foot on the break for a long minute, the removed the fuses for the same amount of time, tried to start.. nothing happened.
    The ecu codes says "12". The battery is fine.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    does your remote work a fair way from your car? key battery could be on its way out. or it may not be making proper contact on the metal around the ignition barrel
    VS V6 Acclaim
    Jul 2008
    I would try hooking a multimeter to the 12v supply to the starter solenoid and see if you are getting current when you try and turn it over.
    StockoVRWagz's Avatar
    StockoVRWagz is offline Formerly White50L
    '94 VR Wagon
    Feb 2008
    Northern Suburbs, SA
    Not trying to start a fight, maybe your hydrogen stuff is the problem? Unhook that see what happens?
    VS 3.8l Exec
    May 2006
    Ya mums house!!!
    before attempting to crank over the car, when you have turned the key to show up your dash lights, do you hear the fuel pump engage?
    i have a feeling it could be a bad connectivity between the key head, and the ignition...
    96 VS II Acclaim
    Dec 2007
    If the immobiliser light is still flashing when your dash lights are ON it will be the keyreader, take the key out and try again.
    You may need to do this a few times.
    Dec 2008
    Braidwood
    Okay job done. It was the ignition barrel that got worn out and finally broke.
    120 bucks for a new one is that a fair deal?
    Thanks everyone for the support you guys are legends.
  15. #15
    vs calais eco
    Sep 2006
    Disney land!
    Quote Originally Posted by Zipster View Post
    I paid $60 for mine new from autobarn but that was on special so i dont think $120 is to bad! I also had this problem with my car (and i still have it) for some reason i have to press the "UNLOCK" button a few times on my key head with the key in the barrel and then it starts without a drama! I would say my battery for my key head is stuffed and giving a weak signal to the BCM, so if this happens again mate, just try that!
  16. #16
    vs exec
    Sep 2009
    I have the same problem with my vs, dash lights on but no crank, the local dealer has replaced the key battery and reprogrammed it but it still does it intermittenley. sometimes shifting the transmission shifter through from rev to low helps but not everytime. the local dealer has checked the park/nuetral switch but every time i take it there it behaves itself. Any other ideas?
  17. #17
    9/04 VZ Calais
    Jul 2009
    broadford
    i have a vs v6 and
    just went out one night and it turns over ok but wont start
    eng code is 12
    ive read a lot here as i was told CAS but now im not sure (plus i dont know where it is)
    any suggestions pls
  18. #18
    9/04 VZ Calais
    Jul 2009
    broadford
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    Quote Originally Posted by cxcxcxvcvcvc View Post
    I have the exact same problem, have to press unlock while the key is in and dash lights are on for it to start, wont start otherwise. Took me a while and a lot of sitting around to figure it out, starts everytime i do that now, wont start if i dont.. :S
  1. ARRRRRH! HELP loud bang bang bang noise
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 10:58 PM
  2. re:big bang
    By VK1981 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-02-2006, 08:42 PM
  3. Bang :(
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2006, 06:14 PM
  4. Bang
    By PhatVN in forum Car Audio
    Last Post: 15-10-2005, 12:19 AM
  5. bang for bux
    By itchy pits in forum V6 Development And Modification
    Last Post: 03-08-2005, 05:44 PM
