hey guys my boot light doesnt work. changed the bulb and still nothing. is there a common reason why these go wrong??
pain in the ass at night when i cant see in my boot.
Bite off more than you can chew, then chew like hell - Peter Brock
have you checked the little push button that turns the light on and off?
just follow the driver's side boot hinge and you'll find it
..had the same problem and i found out that the plug came off the switch =/
hmmm i'll have a look today
remeber the switch is a switching ground so if the screw holding it in is loose this will also cause it not to work
i couldnt find a problem. my wires from the light run back up through the middle of the boot. i couldnt find any loose connections or anything unplugged. can anyone tell me what this looks like or what exactly i should be looking for?
This is what haydz is talking about;
Tighten that up and it should work, its on the right side
yeah i found that thinking thats what he was talking about and mine was on. took it off and put it back on nice and tight (which it was already) and nothing.
