Hey guys i have a Vs Statesman series III centre console and stereo fascia and i was hoping to see if i would be able to fit it in a series I VS Berlina and if anyone else has done or tryed to do it
cheers
plenty people done it, as above take you 2 minutes.
I put one in my calais and it needed some modding to do it! My calais had a flat piece of steel that needed to be removed to be able to get the stereo surround to fit in! also it is a bitch (well was in mine) to line up properly, i take it you also have the dash support panel that goes in behind the stereo surround? if not you will need it as the statesman ones are different from the rest, or you might be able to mod yours but im not really sure!
MY RIDE 96 calais
http://forums.justcommodores.com.au/...96-calais.html
ALSO MY 1972 VALIANT CHARGER IN THE BUILD
http://forums.justcommodores.com.au/...t-charger.html
If it's the same console as mine then yes it will fit. You'll need to modify the bottom console (your original) for the statesman one to fit over unless you were lucky enough to get both pieces already done like me. The stereo surround is fairly easy. You cut your grey piece to allow the cover to go over and the middle horizontal metal support bar thaats under the stereo will need to be taken out. Just a matter of drilling out the welds.
Click for a bigger pic.
yes mate ifs its s3 ur'll get a fair amount of money for in on ebay but i'll put it in if i was u
how much u want
SIR LS1
the two ton go kart
$250 neg and ill find out how much postage will be.
also i will put some pictures up of the statesman seriers III centre console and sterio fascia for you to view
just put it in man there the best console holden made for VN to VS
all u have to do is cut out the section above the radio and it will fit dude
SIR LS1
the two ton go kart
yep i did it for mine
the extra glove box is the bomb !
nah i think ill just sell it cant be stuffed and wat am i just gona have woodgrain in the middle thank you guys for your help ill put it up for sale on the website if you are still interested
i am now willing to sell it for $200
I now have a bought a stato console with radio facia with mini woodgrain glove box. I wish to install on my 2000 vs ute. The utes interior is stock. The stato console has a cig lighter that is hidden by its ash tray cover and sits on an angle.
I did a mock up (test install) over the weekend and I can't see how the stato overlays the original as the original cig lighter looks like its in the way.
Do they actually sit over the top / over lay one another??
Also what happens to the red flashing security light when the stato radio surround goes in, there isn't a place on the stato radio surround for the blinking light?
Is there a "how to" on this topic?
didnt think vs went upto 2000 ...
in utes they did
the utes and i believe also the statesmans did... Series 3
