Results 1 to 12 of 12
Thread: Smell coolant through air vents?
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    Default Smell coolant through air vents?
    Hey guys,
    just wondering if theres anything wrong if i can get a slight wiff of a coolant smell through my air vents (when aircon / heater isnt on) just sitting on lowest setting driving around, theres no coolant leaks etc in the engine bay, is this a problem?
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    VS l67 statesman
    Dec 2008
    Possible heater core leak ,if the leak is small enough I mean pin prick size it will only leak when it gets hot look for coolant under the car near the front of the gearbox but if it is a small leak you probaly wont find anything
    social's Avatar
    Nov 2008
    South Aus
    alrighty thanks mate
    VS l67 statesman
    Dec 2008
    Dont worry too much this is a worse case scenario,it possible the heater core could have been leaking in the past and replaced, and if this has happened the smell never fully goes away ,I blew one in my Vp once
    social's Avatar
    Nov 2008
    South Aus
    well aslong as my car doesnt blow up / eff up then im fine with the smell, il just chuck a BLACK ICE smelly thingo in there haha
    VP ute
    Mar 2006
    I would replace the heater core. Mine ended up leaking into the car and I had to replace all the carpets and clean all the metal of coolant. leave it and you may end up with a rusted out floor pan.
    Big job to get to it too.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    If you can smell coolant and the windscreen fogs up when you first turn on the demister (no A/C) then its heater core time!
    J
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Try some pellets...worked for me.. crush em up and drop them in the radiator works a bit like bars leaks...factory and recomended for my car a vr at sevice ...not sure about vs
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Quote Originally Posted by Social View Post
    Hey guys,
    Have you recently changed the coolant? If some has been spilt somewhere in the engine bay, especially if its a component that gets hot, then you will be able to smell the coolant smell for ages. Maybe give the engine bay a full wash down and see how you go? Other than that, it could actually be leaking somewhere, so check your radiator, radiator hoses, thermostat outlet, heater pipes and connections etc. Failing that, it could be leaking inside the car, as others have mentioned, and that will be the heater core, which is big $$$$ to replace.
    commsirac is offline Banned
    vx
    Aug 2007
    A little bit of spilt coolant can smell for a while. If its only evident through the vents, it could actually be still coming from the engine and being transferred through the plenum grille via the rear bonnet seals not closing properly.
    Chances are though, its a leaky core. as stated ^ if it gets to the stage that the windscreen fogs up when 1st starting the car after its been parked etc, then thats a sure sign.
    The vapor is toxic, assuming you have ethylene glycol in your coolant, so best not have baby too close to the vents.
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    There are two ways to replace the heater core.
    The best way (also the hardest). Remove the entire dash assembly to gain access to the heater box, remove heater box and diassemble to replace core.
    The dodgy way (simpler). Remove center console to the piont where you can see the heater pipes entering the core, drivers side. Cut the pipes to remove core and cut the pipes of the new core in the same place. Fit the new core to the old pipes using heater hose and clamps.
    J
    VP ute
    Mar 2006
    Quote Originally Posted by RX25SE View Post
    J
    but if one of those hoses ever gives, you will be very badly burnt, possibly loose control of the car and crash, possibly into someone else. Lost time from work, burn scars to last a while, not cool and why they were designed the way they were.
    The toughest man in history will not be able to have that happen and pretend it's nothing.
  1. can smell oil in the coolant resivoir
    By mundine in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2009, 07:08 PM
  2. Coolant smell
    By ringfeder3 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2008, 12:40 AM
  3. coolant smell??
    By clarkey3 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2007, 10:57 AM
  4. coolant smell
    By Mark in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2004, 12:48 PM
  5. Fuel smell through air vents
    By nevrl8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-09-2004, 09:14 AM
