Results 1 to 4 of 4
Thread: vn 5 speed to a vs v6 auto
    VN BERLINA MANUAL
    Nov 2008
    WESTERN SUBURBS MELBOURNE
    Default vn 5 speed to a vs v6 auto
    just questioning if a vn v6 5speed box would fit into my vs series II which is currently auto??
    Also wat mods would i need to do?
    ive also been told that factory fitted vn manuals had a different motor then the auto something about the crank? is this the same with the vs?
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    vn and vp are different flywheels, vn, vp and vs are both different motors. you just need a different belhousing far as i know
    SIR LS1
    the two ton go kart
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Yes, if the vn is a series 2 (8 bolt flywheel not 6). It is strongly recommended to get the flywheel 'mirror balanced' to your current auto flex plate that you have since it's coming from a totally different motor so it's a completely different balance.
    VN BERLINA MANUAL
    Nov 2008
    thnx guys for the info i might just go and look for a vs 5speed box i only thought about using the vn 5spped coz my mates got 1 and its been rebuilt and it seems very good. but im sure i can find a decent vs manual box also any suggestions about strocker cranks cams etc for ecotec v6 do i go to crane cams or crow cams or something like that?
  1. VN 4 speed auto in a VB
    By Paiste402 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-02-2008, 10:55 PM
  2. VZ SV6 5 speed Auto
    By CMA in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-12-2007, 11:52 PM
  3. 4 Speed Auto VS 6 Speed Manual?
    By Wicked_D in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-03-2007, 02:09 PM
  4. 5 speed auto vz sv6
    By holiday2 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-10-2006, 01:09 PM
  5. vn v6 5 speed with auto ecm
    By matt2950 in forum V6 Development And Modification
    Last Post: 02-02-2005, 10:27 PM
